OzarkGuy Posted July 8 Posted July 8 Does anyone know where I could source new vacuum elbows that aren't made in china? I see Autozone may have them by Dorman but the reviews are not thrilling with some people saying they dry up and split quickly. I am trying to renew all the vacuum lines for reliability even though the truck runs good now. Some of the fittings are really loose.
GonzoTheGreat Posted July 9 Posted July 9 I had really bad luck with the doorman ones. After two years the rubber hardened, cracked, and caused leaks. I ended up using decent ones from a junkyard that werent as loose as my originals, but I am also interested to hear if anybody has found a better brand.
pizzaman09 Posted July 9 Posted July 9 I just did a lot of searching and didn't come up with much. You could buy high quality silicone vacuum hose and use it as elbows.
Phil86MJX Posted July 9 Posted July 9 I would also be cautious when purchasing the small diameter vacuum hose from NAPA. I thought I was purchasing 10ft continuous and it came in sections.
jodawill Posted July 9 Posted July 9 The Dorman vacuum hose assembly is garbage. I ended up using silicone to get the connections to stay together.
OzarkGuy Posted July 10 Author Posted July 10 I don't know what the actual size of the nipples on the truck are but I think this one is it. Not sure. I agree on not using Dorman. I've read alot of online reviews on how it comes apart in a short time span. This one I found online looks very close to what I think we have. They are sold in 25 or more quantities. I don't care so long as it will last!
jamcomanche Posted 7 hours ago Posted 7 hours ago Amazon has dorman elbows that look the same size as the 5/32 plastic lines. When I replaced mine I ordered 5/32 and 7/32 silicone vacuum tube with some T's and rubber caps and made my own redneck elbows
