ThatJeepGuy Posted 21 hours ago Share Posted 21 hours ago Any wood fence builders or folks that have built their own wood privacy fence? Atm outside of panel construction and not going into the vinyl fence stuff - wood only - how do you set your posts? Sand and gravel, cement, foam, forced into untouched ground? Whats your experience pro/cons on post setting? Epic sunsets for now but soon we'll be shrouding by new modern housing... Link to comment Share on other sites More sharing options...
watchamakalit Posted 14 hours ago Share Posted 14 hours ago Concrete to set the posts. don't buy panels. Build your own it will make a better fence and look nicer in the end. Not a difficult project compared to maintaining jeeps. Link to comment Share on other sites More sharing options...
89 MJ Posted 14 hours ago Share Posted 14 hours ago I would agree, concrete to set the posts. Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted 9 hours ago Author Share Posted 9 hours ago 4 hours ago, watchamakalit said: Concrete to set the posts. don't buy panels. Build your own it will make a better fence and look nicer in the end. Not a difficult project compared to maintaining jeeps. Thats seems to be the consensus ive been finding. Most who buy the pre-made panels either wind up with moldy panles being delivered or poor quality and fitment overall. 4 hours ago, 89 MJ said: I would agree, concrete to set the posts. Follow up question... I plan to set mine 4' deep (atleast 3.5' to beat the frost line in Michigan) I figure the bottom 6" will be gravel/small stone to help disipate water BUT then how much of that remaining 3.5' would i do in concrete? Link to comment Share on other sites More sharing options...
89 MJ Posted 9 hours ago Share Posted 9 hours ago I think that depends on the height that you would want to do the fence. Link to comment Share on other sites More sharing options...
watchamakalit Posted 4 hours ago Share Posted 4 hours ago When I started my fence u got help from a friend who used to install for a living. He told me there in ne indiana that 36" is plenty deep. He was more concerned that I used enough concrete. He said 120lbs per post. I know when I frame decks and buildings we are code required to be 36v deep to get below frost. I'm sure its deeper up there in the artic tundra where you are. Link to comment Share on other sites More sharing options...
