Fan Shroud
Hay I found one at a junk yard but a pic still would be nice
I still have an over heating problem I have changed the thermostat the radiator cap & put on the junkyard shroud it still gets hot also flushed it out
Ok, warm the motor until the thermostat opens. Then turn off the motor. Feel the surface of the radiator. It should be warm top to bottom. If the top is warm and the bottom cold then it's likely the bottom pasages are filled with crud and blocked.
The other possibility is that your water pump is worn and not moving enough fluid.
Did the 2.5 have the same closed cooling system the 4.0 did? If so then make sure the "turtle" coolant bottle is sealing properly. Not holding pressure will lead to boilovers.
Do a pressure check on the Cooling system. it is the easiest way to find if the cooling system has a leak. Are you having to add coolant to the motor? Is the oil milky white, or is it good in color? also does the engine have a sporatic miss in it?
Patrick
Thanks for the Pics
I took the water pump off it had a little wear on the blades I don't know if this is my problem but I ordered a new one anywayhttp://s71.photobucket.com/albums/i145/DCB4GOD/?action=view&current=Fanpump.jpg
