derf Posted March 14 Share Posted March 14 I'm getting close to being ready to pull the Renix 4.0 out of the donor to be put in my next project. I'm starting my to-do list of what to do while it's out. I'm probably going to start with a compression test on the engine before it comes out. If it's low, it'll get a full rebuild. If not, I'd still want to do some work while it is out and easy to get to everything. At the very least, a good cleaning, new gaskets and seals all around. I'm going back and forth on doing a head gasket and new head bolts. Though if I decide to do a new cam, the head would probably come off. So I'm thinking of doing an RV cam that is close-ish to stock. I'm not looking for a big change. But as long as I'm thinking about replacing a worn down cam, may as well do a mild upgrade. Of course, I'll be doing a water pump and thermostat. And even if I don't do a cam, I'll check and potentially swap the timing chain. New injectors are probably a good idea. I have a bored out Renix throttle body already. I'll do all hoses and look at replacement EGR, PCV, and breather. Anything else y'all an think of? Link to comment Share on other sites More sharing options...
89 MJ Posted March 15 Share Posted March 15 I’d throw a water pump at it and thoroughly inspect the freeze plug and possibly replace them. If you pull the head, I’d at least relap the valves too. Link to comment Share on other sites More sharing options...
pizzaman09 Posted March 15 Share Posted March 15 Look over the exhaust manifold for cracks. Link to comment Share on other sites More sharing options...
89 MJ Posted March 15 Share Posted March 15 Maybe do a gasket match port job on the manifolds and cylinder head too Link to comment Share on other sites More sharing options...
derf Posted March 15 Author Share Posted March 15 5 hours ago, pizzaman09 said: Look over the exhaust manifold for cracks. Good idea. 4 hours ago, 89 MJ said: Maybe do a gasket match port job on the manifolds and cylinder head too I do have a kit to do that... Link to comment Share on other sites More sharing options...
75sv1 Posted March 16 Share Posted March 16 Harmonic balancer, timing chain. Oil pump. Stock valve spring up to '95 should be good for .450 lift. I'd have new cam bearings installed. Check the wear for the distributor. New cap, rotor and wires. Brass cap and rotor. Link to comment Share on other sites More sharing options...
