Driving light wiring help....
Just wired up my Hella 450driving lights.... When I flip the switch I hear the relay click but no lights. Am I correct to assume I have a bad connection between the relay and the lights? Pretty sure everything else it wired correctly.... THANKS
Relay has power and ground, so that's good at C175 relay pins 85 & 86, and C102 pins 2 and 5 (10-way connector behind left headlight).
(Convenient time to check/ clean C102 pins for good measure)
C102 pin 6 should read hot at all times.
Relay C175/ pin 87 should send 12V to C370 & C371 pin B with the headlights and fog light switch on.
A single splice feeds power from relay pin 87 to both fog lamps on their pin B. Check incoming power on pin B
A single splice provides ground for both fog lamps on their pin A. Check continuity from C370 & C371 pin A to body ground G103 in the inner LH fender panel.
