turrob6387 Posted February 19 Share Posted February 19 Hello all, Yesterday I installed a new fuel tank and sending unit in my 88 Comanche. Today I went to re run my filler hoses and found that my filler neck had developed rust holes. I'm trying to come up with options to replace it since no new replacements are available. right now I've got 2 options, either I fab a replacement that works, or I find someone with a 3d scanner to scan the filler neck and get the stl file so I can 3d print a replacement out of a filament like PCTG (which is supposedly a fuel grade material). But before i went and did either i was wondering if anyone on here had already scanned and had the STL file they'd be able to share. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 20 Share Posted February 20 The XJ Cherokee filler necks are available and almost the same just a bit longer. You could get one of those and chop it up and weld it back together. Link to comment Share on other sites More sharing options...
amsuco Posted February 20 Share Posted February 20 I'm seeing several used MJ fuel filler necks on eBay. It's another option. Link to comment Share on other sites More sharing options...
TX_Heat Posted February 20 Share Posted February 20 I've had some luck with JB Weld's TankWeld on motorcycle tanks. Prep the neck for best results; don't just apply willy-nilly. Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted Sunday at 03:41 PM Share Posted Sunday at 03:41 PM I think id reach out to one of those fellas commonly found on the MJ part out pages on Facebook. They can be pricey but ive come to accept in some circumstances a bolt in replacement is the way to go over re creating the wheel Link to comment Share on other sites More sharing options...
