Engine shudders
Alright I have my new 4.0 in my MJ and its a big improvement. Found out I have a pin hole leak in the bottom center of my pan so I will have to replace that this weekend at my 500 mile oil change.
The larger issue is that there is a slight shudder over 1800 rpm. It is most noticeable when the rpms are held constant and under load. At first start up I had to adjust the timing by turning the distributor cap to eliminate misfiring. This is not nearly as rough a shudder. I don't know if this makes sense as written but any ideas would be appreciated.
Alright so I thought this went away then it came back and went away and back. The plugs could stand to be replaced but are not awful. The wires and distributor are new but the wires often feel loose when I check them. I am going to get new plugs and do electric grease when I get a chance as well as see if I can't tighten up the connections. I will keep you posted.
Thanks,
Mike
my 99 xj does it every once in a while when its cold and i'm taking off from my drive way. it studders for a second then i stomp on it. the studdering stops and the rear locker kicks in and it wakes up the neighbors.
