cavalier Posted January 16 Share Posted January 16 I just bought a 1992 Jeep Comanche. It's basically the exact spec I wanted, as this truck is meant to replace my Jeep J10 longbed work-truck. It's a five-speed 4x4 4.0 longbed from Idaho, so it's pretty dang clean (but the paint is not perfect from up close). 202,000 miles, but doesn't burn a drop of oil and shifts/drives like new. The only modifications I may make at some point include maybe upgrading the gearing from 3.07s, but DEFINITELY adding A/C, which I realize will be quite a job. I recently drove it 1,000 miles with 1,500 pounds of steel in the bed. It was a tank, though the driver's door doesn't fit that great. Anyway, just saying hi! I bought the truck for $6,400 if anyone is curious. Seemed like that was decent, right? Though the AC job won't be fun or cheap! -DT Link to comment Share on other sites More sharing options...
89 MJ Posted January 16 Share Posted January 16 This seems very familiar. Is this David Tracy from the Autopian? I watched the video on this truck. Link to comment Share on other sites More sharing options...
cavalier Posted January 16 Author Share Posted January 16 Hi 89 MJ! Pleasure to meet you. How do you like the 4:10/31 setup? I'm likely going to end up with 3.55s, though I'm assuming I'll have to fab up a new bracket for that load-sensing brake valve rod. -DT Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 16 Share Posted January 16 Welcome and congratulations, when you get a chance drop its VIN in the registry. https://comancheclub.com/forum/35-1992/ Link to comment Share on other sites More sharing options...
hgeranium Posted January 16 Share Posted January 16 1 hour ago, cavalier said: I just bought a 1992 Jeep Comanche. It's basically the exact spec I wanted, as this truck is meant to replace my Jeep J10 longbed work-truck. It's a five-speed 4x4 4.0 longbed from Idaho, so it's pretty dang clean (but the paint is not perfect from up close). 202,000 miles, but doesn't burn a drop of oil and shifts/drives like new. The only modifications I may make at some point include maybe upgrading the gearing from 3.07s, but DEFINITELY adding A/C, which I realize will be quite a job. I recently drove it 1,000 miles with 1,500 pounds of steel in the bed. It was a tank, though the driver's door doesn't fit that great. Anyway, just saying hi! I bought the truck for $6,400 if anyone is curious. Seemed like that was decent, right? Though the AC job won't be fun or cheap! -DT Welcome and well done on the purchase! I say that the price you paid is more than fair for the spec you have. I paid $5000 for my 2x4 4.0 AW4 eliminator with ~173k for reference, which I think was also a fair price for the condition. Link to comment Share on other sites More sharing options...
James92 Posted January 17 Share Posted January 17 Welcome! I love this truck. Must be siblings with mine. Curious what route you are going with for adding AC? Link to comment Share on other sites More sharing options...
89 MJ Posted January 17 Share Posted January 17 16 hours ago, cavalier said: Hi 89 MJ! Pleasure to meet you. How do you like the 4:10/31 setup? I'm likely going to end up with 3.55s, though I'm assuming I'll have to fab up a new bracket for that load-sensing brake valve rod. -DT I do like the 4:10s with 31s quite a lot. In traffic, it’s hard to beat the 4:10s for the ease of launching. If I could do my truck again, I’d either go up to 33s or drop down to 3:73 gears. My truck spends a lot of time on the highway and is turning roughly 2200 at 60 mph. That said, my truck has still gotten 20 mpg running 75 mph. Personally, I don’t think a 3:55 is quite enough gear when you’re in traffic. It would be great on a freeway, but a little lacking around town. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted January 18 Share Posted January 18 $6400 is pretty good in my book. mine was $4100 but needed nearly everything. 270k miles. part of my build is in my footer. I mean, yours is a 92, can you put a price on perfection? Link to comment Share on other sites More sharing options...
Gjeep Posted January 25 Share Posted January 25 Nice find. I've installed AC in 2 trucks now -- one a few months back, 1991 MJ same era as yours. Not sure what regulations/ your preferences are for refrigerant, but I upgraded both of my HO era MJ's with the later 1995 XJ factory R134 system. If you decided to go this route ping me as I can provide you the necessary part#'s. In general, you'll need a new heater/evap box under the dash as it is different than the non-AC box. You'll also need an AC truck (XJ/MJ) vacuum harness that runs just above the box assembly. You'll need an AC dash control bezel and I'd suggest a heater core based on your miles (get a quality copper brand, factory is no longer available); and an evaporator (again quality) for inside the box. All the lines under the hood, drier, condenser for in front of the radiator, relief valve, cut-off switch, engine bracket for the compressor, a compressor, expansion valve (sits between the evaporator and engine hoses, and I'd suggest a new blower motor as my first gen XJ's typically started to fail around 250K. If you're scavenging from a wreck of the same year (R12 system) you'll probably have most of what you need. But but new items as I mentioned above. It's a job. Time consuming, but worth it. And I suggest removing the dash entirely to access the HVAC box. A lot of guy just pull the passenger side out, but my thinking is it's bound to bend and break things.. Just take your time as ask questions as you need. Link to comment Share on other sites More sharing options...
Warthog Posted April 6 Share Posted April 6 Can you give me part numbers? Got an 87xj with original box and a 90 box going in an 86 mj. Updating the heater core and evaporator. Says there’s a difference in the 87-91, then 92-95? Gonna install sbc in both so I’m aware of needing custom hoses. I just want to get the better of the two set ups and not sure which or if I can even go with a later model evaporator.first jeep builds and definitely first ac replacement. Gonna cap em til I’m ready to hook up. Hope that makes sense and you can give me some guidance. Many many thanx in advance! Link to comment Share on other sites More sharing options...
Gjeep Posted 17 hours ago Share Posted 17 hours ago I'm fairly certain with proper HO brackets you can get the basics installed but merging the renix era electric to HO I havent been through but anything is possible. I havent been down that road to recommend it. I would suggest keeping renix era AC. Link to comment Share on other sites More sharing options...
