Aftermarket fuel tank
mine fit fine. :L:   now's the time to also order a strap kit with bolts as they like to break from rust.  and probably wouldn't hurt to get a new pump with sender assembly too.  oh, and be prepared to get some rubber hose if you have to slice your fill hose apart to drop the tank because the clamps froze up.  factory has a slight kink to it, but I'm told straight can work fine.  oh, and replace any rubber fuel line too.    be sure to use only stainless hose clamps.
get it all done at once.  :L:
Spectra tank is great, but those new straps no matter how you try and bend them won't be right. Use the factory straps -- if yours are rusted, find some factory straps on ebay/ FB marketplace. You'll also want to identify the straps when you remove the tank 'front' and 'rear' as they will be shaped to fit accordingly.
50 minutes ago, comanche32 said:
Thanks for the information luckily my straps are in good shape
treat the J-bolts like they are the most fragile things on the planet.  clean the threads thoroughly and apply pb blaster ahead of time.  I snapped one on a rust free truck. :(
one like this:  https://www.ebay.com/itm/355720940735
I had originally purchased a more expensive unit, but it turned out the pump was only attached at the top and it sorta parted ways when I installed it, so I went with the cheaper one purely because it had a clamp at the top and at the bottom.  seems to work just fine a year later. :L:  do make sure you buy from a seller that has a lot of feedback and warranties the part for 30 days.  and be prepared to install it right away so you get plenty of time proving it works.  cheap electrical parts tend to fail quickly if they are going to fail.
