joeCor Posted August 28, 2025 Share Posted August 28, 2025 I bought the Carter p74155 pump. It is way to big and the strainer that it came with fits to loose to connect. Think I’m going to get the Bosch 69302. Looks like it doesn’t come with a strainer. Anyone know which strainer to get? 87 longbed 2.5L base Link to comment Share on other sites More sharing options...
joeCor Posted August 28, 2025 Author Share Posted August 28, 2025 Just now, joeCor said: I bought the Carter p74155 pump. It is way to big and the strainer that it came with fits to loose to connect. Think I’m going to get the Bosch 69302. Looks like it doesn’t come with a strainer. Anyone know which strainer to get? 87 longbed 2.5L base When I pulled the old pump it had no strainer. Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted August 28, 2025 Share Posted August 28, 2025 Is the strainer rolling around, loose in the bottom of the tank? Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 28, 2025 Share Posted August 28, 2025 The Bosch 69302 uses a factory style strainer. Get one that is listed as fitting your truck. It will look like this Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 28, 2025 Share Posted August 28, 2025 87 2.5. I wonder if your sending unit is leftover stock for the 86’s. Link to comment Share on other sites More sharing options...
