1999 MJ Posted August 3 Share Posted August 3 (edited) The curse strikes again. It’s one of those things, where you are driving around and you can spot it a mile away. So, I stopped and talked to the owner. He’s currently looking for a wiring harness and a computer, to get it running and back on the road. Says he’s the second owner, with his uncle being the first. Sounds like the fuse block went south. I’m assuming, due to the clutch master cylinder leaking on it? Year, Make, Model. 1987, Jeep, Comanche (MJ) Image, if available See Below Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 2.5 / Manual / 2wd / 2wd / unknown / short bed Build date: (its on the driverside door sticker, in the form of month and year) Missing / Repainted Current Location: Region will do, state, and area of state. Guam Status: Is it still on the road? Work In Progress White in Color. Red / Maroon Bench Seat. Has a plastic bed liner. Sliding rear window. Not sure what the rims belong to??? Edited October 10 by fiatslug87 Corrected VIN Link to comment Share on other sites More sharing options...
jdog Posted September 19 Share Posted September 19 VIN not found, when ran with last 8 comes back as XJ Link to comment Share on other sites More sharing options...
Pete M Posted September 19 Share Posted September 19 On 8/3/2025 at 7:44 AM, 1999 MJ said: The curse strikes again. It’s one of those things, where you are driving around and you can spot it a mile away. So, I stopped and talked to the owner. He’s currently looking for a wiring harness and a computer, to get it running and back on the road. Says he’s the second owner, with his uncle being the first. looks like it got a new dash along the way. look here for another VIN tag: Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 3 Share Posted October 3 On 9/19/2025 at 1:44 PM, Pete M said: looks like it got a new dash along the way. But the “T” in position 3 identifies it as a Truck (MJ) a “4” would be a MPV (XJ). Link to comment Share on other sites More sharing options...
Pete M Posted October 3 Share Posted October 3 could be a dash from another MJ @1999 MJ Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 3 Share Posted October 3 @1999 MJ Is the next to last digit possibly an 8 instead of a 6? Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 3 Share Posted October 3 2 minutes ago, fiatslug87 said: @1999 MJ Is the next to last digit possibly an 8 instead of a 6? Looks like an 8. It has a curve vs being straight Link to comment Share on other sites More sharing options...
jdog Posted October 10 Share Posted October 10 BODY: TL61 BUILD: 09/26/86 SELLING DEALER: WILLS MOTOR CO TWIN FALLS, ID *X1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE APA MONOTONE PAINT CBA STRAIGHT BACK BENCH SEAT CGX RR HEAD RESTRAINTS OUTBOARD SEATING DCB MANUAL TRANSMISSION EPD 2.5 L I4 ENGINE GAC TINTED GLASS WINDOWS GFD REAR SLIDING WINDOW GPB FOLD MIRRORS HCC JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER LAP SHIFT INDICATOR WARNING LAMP LMA HALOGEN HEADLAMPS MBJ BLACK FRONT BUMPER MDA FRONT LICENSE PLATE BRACKET NAA FEDERAL EMISSIONS PXB Olympic White QXB Olympic White SBA POWER STEERING TBG COMPACT SPARE TIRE WMC OPEN 3LQ DESCRIPTION NOT AVAILABLE Link to comment Share on other sites More sharing options...
