Pinging under load need help
I have a 90 comanche renix 4.9 stroker low compression pistons 64mm tb 24lbs injectors 50psi fpr 2001 intake manifold borla headers stock cam shaft
ive been battling pinging for a while now got the rem not that long ago hoping i would figure out why.
it pings when its in 3rd 4th cruising anywhere from 35mph and want to speed up
rems showing high knock and ign timing in the 40s doesn’t seem to drop
i have all the stock sensors hooked up
also ive tried 91 oct and still does it
if i full throttle it ign timing is in the low 20s and no pinging at wot
ive been wanting to try and do the high altitude mod but backwards to retard a bit but I'm not sure if the ecu is just gonna correct it
any help greatly appreciated
4 minutes ago, 89 MJ said:
Sounds like your knock sensor might be failing. This is exactly what it’s supposed to prevent.
Something i didn’t state it was cut on my harness and don't remember how i connected it idk if its backwards if it will do its job or not
Shifting the CPS either CW or CCW only fools the ECU to thinks a cylinder is at TDC when it is not. Shifting will also shift, for each cylinder, when KNOCK looks for ping and when the INJ fires. The ECU seems to be able to handle CPS ADVANCE, not sure on CPS RETARD.
I'd pin it out, back to the ECU just to make sure.
I'm going to hold of on messing with cps rn
I'm going to check the knock plug to ecu for continuity and found a page hopefully its accurate in how the wires go following how its pictured and get a new better knock sensor i have a autozone in it rn
Do you happen to know what your quench distance is? Low comp strokers have had these issues before. Has the cam timing been adjusted at all? And when you say stock cam, is it an oe renix cam? What’s your actual stroker recipe/combo?
I do not off the top of my head
and cam is a stock ho cam from a 91-95
And by cam timing adjusted what do you mean by that exactly
my stroke is 3.895 rod 6.125 bore is 4”
Did you degree in the camshaft using an adjustable timing set?
3 minutes ago, ghetdjc320 said:
Has it always has this pinging issue since it was built or is this a new issue?
Its a pretty new issue i use to have a big cam and race it
then i made it my daily took motor out refreshed it and put a stock cam and no ping then it started and thats when i started connecting all the sensors i had unplugged like o2 knock distributor sync and even bought the rem from nick that has helped alot with finding problems that i was unaware of
i feel like some days it won’t do it till its at 200-210 temp and the hottest point of the day for me which is like 110-115 degrees
and some days does it since i get in it and start it
Interesting, one more question: have you always ran it on the same Renix system? And is it the 89-90 or the earlier ECU?
Yes always renix
its a 90 harness and 428 ecu
i just took off msd box and coil and went to oem stuff i had
