87-90 MJ bucket seat belts needed
Colt6920
These should be the same as Cherokee ones. That should help widen your search some. I'd recommend checking out car-part.com. That will check junkyards within a specified radius of your zip code. If you search that for larger parts, like a seat, you'll probably get more results because few junkyards will list every small item, such as a seat belt.
2 hours ago, eaglescout526 said:
I think you can also get new ones too. 87-90 are made by Bendix and we’re common place in GMs and Fords of the same era. That should widen your search more.
Thank you both as that is very helpful.  My friend gave me some for a newer Cherokee which did not work.
