Colt6920 Posted June 23, 2025 Share Posted June 23, 2025 I'm looking for a pair of gray female seatbelts, the ones that can mount to the transmission tunnel. Looking for a pair in nice condition. Link to comment Share on other sites More sharing options...
89 MJ Posted June 23, 2025 Share Posted June 23, 2025 These should be the same as Cherokee ones. That should help widen your search some. I'd recommend checking out car-part.com. That will check junkyards within a specified radius of your zip code. If you search that for larger parts, like a seat, you'll probably get more results because few junkyards will list every small item, such as a seat belt. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 23, 2025 Share Posted June 23, 2025 I think you can also get new ones too. 87-90 are made by Bendix and we’re common place in GMs and Fords of the same era. That should widen your search more. Link to comment Share on other sites More sharing options...
Colt6920 Posted June 23, 2025 Author Share Posted June 23, 2025 2 hours ago, eaglescout526 said: I think you can also get new ones too. 87-90 are made by Bendix and we’re common place in GMs and Fords of the same era. That should widen your search more. 2 hours ago, 89 MJ said: These should be the same as Cherokee ones. That should help widen your search some. I'd recommend checking out car-part.com. That will check junkyards within a specified radius of your zip code. If you search that for larger parts, like a seat, you'll probably get more results because few junkyards will list every small item, such as a seat belt. Thank you both as that is very helpful. My friend gave me some for a newer Cherokee which did not work. Link to comment Share on other sites More sharing options...
JolietJEEP'84 Posted June 25, 2025 Share Posted June 25, 2025 I think I've got a pair. I'll check and confirm tomorrow. Link to comment Share on other sites More sharing options...
JolietJEEP'84 Posted June 25, 2025 Share Posted June 25, 2025 I have a passenger side. Pretty sure I've got a local yard I can grab the driver's side from Link to comment Share on other sites More sharing options...
JolietJEEP'84 Posted June 27, 2025 Share Posted June 27, 2025 Link to comment Share on other sites More sharing options...
