ja_racing Posted June 22, 2025 Share Posted June 22, 2025 Comanche 90 any suggestions showing inside gauge at 10-11v with blower motor on and lights any tips to get it higher test it at the battery and its at 13.9v annoying that my rem keeps throwing code for low voltage Link to comment Share on other sites More sharing options...
AZJeff Posted June 22, 2025 Share Posted June 22, 2025 For starters, do NOT rely on the guage on the instrument panel to give you accurate voltage readings. Instead, measure the voltage on the battery terminals directly using a VOM. Additionally, with the blower on full tilt and with all exterior lights on, those devices probably draw more current than your alternator can deliver at idle. That would cause a less than fully charged battery to begin to show a voltage slump. this can be confirmed by running engine RPM up to 1500 or higher, and measuring battery voltage with a VOM while all of those devices are turned on. Link to comment Share on other sites More sharing options...
ja_racing Posted June 22, 2025 Author Share Posted June 22, 2025 22 minutes ago, AZJeff said: For starters, do NOT rely on the guage on the instrument panel to give you accurate voltage readings. Instead, measure the voltage on the battery terminals directly using a VOM. Additionally, with the blower on full tilt and with all exterior lights on, those devices probably draw more current than your alternator can deliver at idle. That would cause a less than fully charged battery to begin to show a voltage slump. this can be confirmed by running engine RPM up to 1500 or higher, and measuring battery voltage with a VOM while all of those devices are turned on. I'm measuring at the battery with a volt meter and it reads from 13.9v-14v with ac full blast and all lights on at night i have a higher amp alternator i know I'm fine, i don't care for the gauge to much but i have nicks rem device and throws a code for low voltage i might just look into how to correct the volt reading on the diagnostic port so it doesn't throw the code Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 22, 2025 Share Posted June 22, 2025 Grounds grounds grounds. Make sure they’re all clean and new ones added and old ones replaced if needed. Link to comment Share on other sites More sharing options...
ratrapp Posted June 22, 2025 Share Posted June 22, 2025 the 88 i had showed a good volt less than what it actually was.my grandmother bought it when it was a year old with only 10k miles on it and it had always been off some.factory gauges arent always the most accurate. Link to comment Share on other sites More sharing options...
AZJeff Posted June 23, 2025 Share Posted June 23, 2025 I will admit I am not familiar with how the REM device actually measures voltage, so I cannot comment on why you are seeing that device reporting low voltage while the battery is just fine. sorry Link to comment Share on other sites More sharing options...
Ωhm Posted June 23, 2025 Share Posted June 23, 2025 What is Battery Voltage (VLT) on the REM? Link to comment Share on other sites More sharing options...
ja_racing Posted July 3, 2025 Author Share Posted July 3, 2025 On 6/22/2025 at 5:28 PM, Ωhm said: What is Battery Voltage (VLT) on the REM? It will start off at 12.4-12.5 then be 12-11.8 Link to comment Share on other sites More sharing options...
ja_racing Posted July 8, 2025 Author Share Posted July 8, 2025 On 6/22/2025 at 5:28 PM, Ωhm said: What is Battery Voltage (VLT) on the REM? Do you have a rem if show what is yours displaying Link to comment Share on other sites More sharing options...
Ωhm Posted July 8, 2025 Share Posted July 8, 2025 Anyone with a REM hookup. Do you see the same voltage (VLT) as listed below? This displays the current voltage of the Battery. Note: On 4.0L this may be the Fuel Pump/o2 Relay Circuit which will normally read 0v after 3 seconds when the engine is off. This will read correctly when the engine is running. – Engine Off (~12.4-12.8) A healthy battery will rest around 12.6 Volts – Engine Idle (~13.5-14.5) A healthy Alternator should supply 13.5-14.5 Volts Link to comment Share on other sites More sharing options...
