DansGreyMj Posted January 12, 2008 Share Posted January 12, 2008 i recently put door speakers in my mj (didn't have them before), the windows roll down fine, but when i go to roll them up the speaker is in the way of the "corkscrew" thing. Is there a part from the factory that blocks the thing from hitting the speaker? My mj did not have door speakers from the factory so I figure there must be some parts missing. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 12, 2008 Share Posted January 12, 2008 the "corkscrew thing" shouldn't be exposed much...it should have a tube around it Link to comment Share on other sites More sharing options...
beaterjeep Posted January 12, 2008 Share Posted January 12, 2008 I have brand new Pioneers in my 86 and they don't get in the way of the windows at all. Maybe your's are just too deep for the space in there? That's the only thing I can think of. Link to comment Share on other sites More sharing options...
offroader461 Posted January 12, 2008 Share Posted January 12, 2008 i replaced the OEM's with some sony's awhile back and have no problems with rolling the windows down Link to comment Share on other sites More sharing options...
jtdesigns Posted January 12, 2008 Share Posted January 12, 2008 I'm not 100% sure,but isn't the end of the cable pointing toward the rear of the truck? Like maybe yours was moved to point straight up, or toward the front..... Is this correct?? edit:: you know, on my trucks doors, I was missing the rubber in which the corkscrew was housed in. It was just laying in the bottom. When I put it back on I took a small zip tie and used that to hold it on. When the rubber "tube" was off you could hear it rattle around inside the door. Does this sound like it might be what yours is doing? Link to comment Share on other sites More sharing options...
DansGreyMj Posted January 12, 2008 Author Share Posted January 12, 2008 mine don't have a tube on them, can they be adjusted in which direction they go? Link to comment Share on other sites More sharing options...
jtdesigns Posted January 12, 2008 Share Posted January 12, 2008 mine don't have a tube on them, can they be adjusted in which direction they go? I know for sure the cable has a rubber tube, as for if it points to the rear or front, I'm not 100%. I was thinking it pointed to the rear...... Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 12, 2008 Share Posted January 12, 2008 mine don't have a tube on them, can they be adjusted in which direction they go? I know for sure the cable has a rubber tube, as for if it points to the rear or front, I'm not 100%. I was thinking it pointed to the rear...... Correct, they point toward the rear along the bottom of the door. On my power window regulators (the manuals had them too) there is a push-in "Christmas Tree" attached to the tube that plugs into a hole to keep it from sliding around. Link to comment Share on other sites More sharing options...
DansGreyMj Posted January 12, 2008 Author Share Posted January 12, 2008 i got he passenger side situated but i can't get the driver side to go towards the rear ill probably put a small piece of angle iro to block it form hitting the speaker Link to comment Share on other sites More sharing options...
