AnotherOldJeepGuy Posted Friday at 12:39 AM Author Share Posted Friday at 12:39 AM Got the new one. Cable moves freely, the old one definitely does not. Seems promising! Install is gonna be Saturday morning, will post how it goes. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted Saturday at 07:31 PM Author Share Posted Saturday at 07:31 PM New cable is in! Wow that was much harder than I even expected. Getting the cable routed into the cabin with the mounting bracket key lining up was many trial and errors. That thing can't be rotated once routed into the cabin so it's many trial and error attempts removing, rotating, and rerouting trying to hit the alignment. My last attempt got the key close enough that I could twist it a little and line it up. At that point one would have thought the snap on ring would be rotated correctly to line up and snap on pin, but no, still had to rotate it quite a bit. BUT it's in there. Shifting works but it's a little stiff, I am assuming this is because it is twisted some, and my hope is it "gets happy" after some use and shifts better. I'll post back if that happens, or not. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted Sunday at 02:33 PM Author Share Posted Sunday at 02:33 PM I discovered this loose connection during the job. It looks like it was not connected prior to the work judging from the condition of the connectors. and also because I don't remember pulling on anything hard enough to pull off a connection (but it would not be the first time I did it). Perhaps a connection for an instrument cluster gauge that I don't have since I only have lights in there? Link to comment Share on other sites More sharing options...
Gojira94 Posted Sunday at 02:56 PM Share Posted Sunday at 02:56 PM Looks like the rear washer motor connector, now missing its plastic. Not used on MJ, the same portion of harness was used for XJs that had an additional washer motor for the rear. Fine just like it is- tuck it or zip tie it to something out of the way. Link to comment Share on other sites More sharing options...
llhat Posted Sunday at 05:11 PM Share Posted Sunday at 05:11 PM not in disagreement for purpose, but separate wires, insulate them before tying them off out of the way.... looks shorted already Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted Sunday at 05:25 PM Share Posted Sunday at 05:25 PM 2 hours ago, AnotherOldJeepGuy said: I discovered this loose connection during the job. It looks like it was not connected prior to the work judging from the condition of the connectors. and also because I don't remember pulling on anything hard enough to pull off a connection (but it would not be the first time I did it). Perhaps a connection for an instrument cluster gauge that I don't have since I only have lights in there? Those are the wires for the washer level sensor a feature not offered on the Comanche but was present on the Cherokees. Those wires are not attached to anything. The cabin side of the harness was never there. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted Sunday at 06:51 PM Author Share Posted Sunday at 06:51 PM 1 hour ago, llhat said: but separate wires, insulate them before tying them off out of the way.... a good addition, but in this particular case sounds like it really doesn't matter much... 1 hour ago, Eagle_SX4 said: Those are the wires for the washer level sensor a feature not offered on the Comanche but was present on the Cherokees. Those wires are not attached to anything. The cabin side of the harness was never there. Ah, interesting. My car has that... Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted Monday at 03:57 PM Author Share Posted Monday at 03:57 PM Should I be at all concerned that shifting with this new cable is not as smooth as it was before? Or is this normal for a new cable and it should get smoother with a little use? Link to comment Share on other sites More sharing options...
