Anthi4078 Posted April 20, 2025 Share Posted April 20, 2025 Hey has anyone ever modified our stock tachs to work with a V8? I found a thread for a YJ but it was a 95 and I’m not sure how similar our clusters are to those “other” jeeps In that they swapped out a resistor and were able to adjust the Guage to work. Any insight would be helpful. Thanks Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 20, 2025 Share Posted April 20, 2025 The 87-96 clusters have a pot on the tach that can be adjusted and more than likely read a V8 Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 20, 2025 Share Posted April 20, 2025 10 hours ago, eaglescout526 said: The 87-96 clusters have a pot on the tach that can be adjusted and more than likely read a V8 Link to comment Share on other sites More sharing options...
Flexj Posted April 22, 2025 Share Posted April 22, 2025 On 4/19/2025 at 10:45 PM, eaglescout526 said: The 87-96 clusters have a pot on the tach that can be adjusted and more than likely read a V8 Mine has 4 cylinder and 6 cylinder on the back. Only those two options... If there is a dash that has a v8 option please I want to know where so I can do this also!! lol Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 22, 2025 Share Posted April 22, 2025 8 minutes ago, Flexj said: Mine has 4 cylinder and 6 cylinder on the back. Only those two options... If there is a dash that has a v8 option please I want to know where so I can do this also!! lol V8’s use 4cyl mode most of the time. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 22, 2025 Share Posted April 22, 2025 15 minutes ago, Flexj said: Mine has 4 cylinder and 6 cylinder on the back. Only those two options... If there is a dash that has a v8 option please I want to know where so I can do this also!! lol You sure? That pot can be adjusted pretty far. Link to comment Share on other sites More sharing options...
Flexj Posted April 22, 2025 Share Posted April 22, 2025 5 minutes ago, eaglescout526 said: You sure? That pot can be adjusted pretty far. I'm certain mine only has a 4 cylinder and 6 cylinder marked on it... But I'm looking for more info if the v8 is an option!! Maybe ill pull the dash again and get a picture.. Link to comment Share on other sites More sharing options...
Flexj Posted April 22, 2025 Share Posted April 22, 2025 13 minutes ago, ghetdjc320 said: V8’s use 4cyl mode most of the time. Really???? Ill give that a shot if thats the case! Ill get the picture and if theres no v8 option like eaglescout is suggesting ill just click it to the 4 cylinder spot. Thank you! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 22, 2025 Share Posted April 22, 2025 35 minutes ago, Flexj said: Really???? Ill give that a shot if thats the case! Ill get the picture and if theres no v8 option like eaglescout is suggesting ill just click it to the 4 cylinder spot. Thank you! Yep, should work for most applications Link to comment Share on other sites More sharing options...
