jeff_magoo Posted March 12, 2025 Share Posted March 12, 2025 She is in rough shape, had to replace ECU (it was solen) but does run. Loads of work yet. She will become my Daily Link to comment Share on other sites More sharing options...
jdog Posted March 14, 2025 Share Posted March 14, 2025 BODY: JL62 BUILD: 07/02/91 SELLING DEALER: BIG 4 MOTORS TSUUT'INA, AB CANADA *C1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE ACC OPTION PACKAGE ADH HEAVY DUTY ELECTRICAL GROUP ADLA SKID PLATE GROUP ARL BAFP 130 AMP ALTERNATOR BCDP 550 AMP MAINTENANCE FREE BATTERY CBAP STRAIGHT BACK BENCH SEAT CKAP CARPET DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DHTP SHIFT-ON-THE-FLY,P/TIME T/CASE DRKP REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GEC FRONT LEFT SIDE SLIDING WINDOW GFDA REAR SLIDING WINDOW GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR HAA AIR CONDITIONING JHAA VAR INTERMITTENT WINDSHIELD WIPERS JJAP CIGAR LIGHTER KKSP STRIPE/BADGE/MOLDING/COLOR KWSP STRIPE/BADGE/MOLDING/COLOR K2BP STRIPE/BADGE/MOLDING/COLOR K27P DO NOT USE MBJP BLACK POWDER COATED FRONT BUMPER MHAP BLACK WINDSHIELD MOLDINGS MMKP PW7 BRIGHT WHITE CLEAR COAT RAAC ALL RADIO EQUIPPED VEHICLES RABP OPEN RCDP 4 SPEAKERS SFBP FRONT HEAVY DUTY SHOCK ABSORBERS SGBP REAR HEAVY DUTY SHOCK ABSORBERS TBBP FULL SIZE SPARE TIRE TRPA TIRES TZAP GOODYEAR BRAND TIRES WJDP WHEELS WLYC ALL STEEL WHEELS YGAA WITHOUT BILLABLE FUEL Z01P REAR SPRING GROUP I Z5B PAYLOAD RATING - 1800# Z59P LEFT FRONT SPRING GROUP IX Z78P RIGHT FRONT SPRING GROUP VIII 3N8A DRIVE AWAY PROGRAM TRACKING 4CPA FEDERAL A/C EXCISE TAX 4HA SPECIAL SCHEDULING CONDITION I APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES DGSS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHAS LOCK-UP TORQUE CONVERTER DHNS COMMAND-TRAC PART TIME 4WD SYSTEM DJHS 230MM FRONT AXLE DMDS 3.55 REAR AXLE RATIO GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GTZS MANUAL REMOTE MIRRORS JAZS DO NOT USE - SEE JP, KA CLASSES JDBS 180 KPH PRIMARY SPEEDOMETER K3WS STRIPE/BADGE/MOLDING/COLOR LBCS GLOVE BOX LAMP LMAS HALOGEN HEADLAMPS LMKS DAYTIME RUNNING HEADLAMPS, HIGH BEAM MB1S BLACK FRONT BUMPER MDAS FRONT LICENSE PLATE BRACKET MFFS BLACK GRILLE MMCS MMGS BELT MOLDINGS NAAS FEDERAL EMISSIONS NBKS EVAP CONTROL SYSTEM NF5S 23 GALLON FUEL TANK NHKS ENGINE BLOCK HEATER QW7S BRIGHT WHITE CLEAR COAT SBAS POWER STEERING SCES STEERING WHEEL TBMS TIRE CARRIER WINCH XBSS PICKUP BOX YACS BUILD TO CANADA MKT. SPECIFICATIONS 1ABS CANADA DEALER RETAIL 125S ZONE 25-CANADA-ALBERTA Link to comment Share on other sites More sharing options...
The86manche Posted March 14, 2025 Share Posted March 14, 2025 I've seen worse. At least she's in one piece! And it's an ho Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 16, 2025 Share Posted March 16, 2025 ...and a Pioneer Big Ton Link to comment Share on other sites More sharing options...
jeff_magoo Posted March 23, 2025 Author Share Posted March 23, 2025 On 3/14/2025 at 12:00 PM, The86manche said: I've seen worse. At least she's in one piece! And it's an ho Yeah, but no rust, and no dents on the "frame", It only looks gross, but she won'y be a a car show queen like my other one Link to comment Share on other sites More sharing options...
Pete M Posted March 23, 2025 Share Posted March 23, 2025 once she's up and running you should take both to the car shows. Link to comment Share on other sites More sharing options...
