eaglescout526 Posted January 30, 2025 Share Posted January 30, 2025 I know, not MJ but I need some help and schooling. Guy local is having some issues with his CJ. It has a Mopar injection kit with the 4.2Litre. I believe these to basically be HO injection systems and not Renix. I know a little bit about HOs, but not enough and I want to help this guy out as theres not many mechanics in the state to get this system running right. So when cold, it runs rough, almost undrivable and owner feels like he is hurting it. Gets warm, little more drivable but still an issue. He had an issue with cylinder 6 injector and had it replaced. Was a little better. Then replaced thermostat, cap, rotor, not sure if the plugs were but he said a basic tune up was performed and it helped run better but not to where the issue has gone away. What sensor could be doing this? 91-92 owners have any thought? Any thoughts or ideas? Maybe any tools or knowledge and literature will help me greatly. @89 MJ, 4.2Litres do not have adjustable valves correct? Link to comment Share on other sites More sharing options...
89 MJ Posted January 30, 2025 Share Posted January 30, 2025 Correct, the valves are not adjustable on the 258s. Does the computer control the timing too? Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted January 30, 2025 Share Posted January 30, 2025 I built the junkyard version of that conversion to run in my Eagle. It is all based on the 95 4.0 injection. Maybe check the map sensor sometimes they go bad. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 30, 2025 Author Share Posted January 30, 2025 2 minutes ago, Eagle_SX4 said: Maybe check the map sensor sometimes they go bad. This was something I did bring up to the owner, he did rebuttal with it should affect the engine and not just cyl 6 when unplugging the injector. But again, HO's are new-ish to me, I cant imagine the theory of operation being drastically different from Renix 4.0. Owner could be right about that, You and I could be right about the MAP. I will see this CJ in person this weekend. I did leave out a detail, the engine was swapped with another engine that has this injection set up. Something about the original block being cracked and the head was swapped to the doner engine. Let me ask ya Eagle, since this is HO, how could we check to see if it has any codes? Scan tool or would I be able to rig up some sort of light? Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted January 30, 2025 Share Posted January 30, 2025 1 minute ago, eaglescout526 said: Let me ask ya Eagle, since this is HO, how could we check to see if it has any codes? Scan tool or would I be able to rig up some sort of light? If this was indeed the Mopar kit it should have a check engine light somewhere. The codes are just a series of blinks and pauses. This thread shows how to read them. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 30, 2025 Author Share Posted January 30, 2025 24 minutes ago, Eagle_SX4 said: If this was indeed the Mopar kit it should have a check engine light somewhere. This is what I’m hoping for. Will a multimeter help me out for diagnosing his issues? Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted January 30, 2025 Share Posted January 30, 2025 5 hours ago, eaglescout526 said: This is what I’m hoping for. Will a multimeter help me out for diagnosing his issues? Yes it could but unlike the Renix system I haven't been able to find much info out there for testing all the components. Most of the time the fault codes will point you in the right direction. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted January 30, 2025 Share Posted January 30, 2025 I found the instructions for the kit. Oddly they are on Quadratec's website. https://www.quadratec.com/sites/default/files/installation_instructions/2688.pdf Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted January 30, 2025 Share Posted January 30, 2025 The check engine light info starts on the bottom of page 13. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 30, 2025 Author Share Posted January 30, 2025 1 hour ago, Eagle_SX4 said: I found the instructions for the kit. Oddly they are on Quadratec's website. https://www.quadratec.com/sites/default/files/installation_instructions/2688.pdf What an odd place to find the instructions! Thanks Eagle! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 1, 2025 Share Posted February 1, 2025 I’m familiar with these kits. Had one in my 88 YJ with the 258 for a while before building a stroker. These kits run a dampener mounted CPS. Those were problematic as they were exposed much more than the bell housing mounted units. They are Hall effect cps units. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 1, 2025 Author Share Posted February 1, 2025 Actually.... yall aint gonna believe this. After looking at it for about half an hour listening to it run and figuring out sensors and examining things like the spark plug wire which he will have to get a new one...it was the injector. Same cylinder he was having issues with. So I swapped 6 for 1 and 1 to 6 and the problem literally went away. Now 5 of the injectors are still original Siemens Chrysler injectors except 6. I think 6 is on a crutch by being in the front with my thinking being that pressure isnt enough in the back of the rail to feed that injector and by having an OEM one in the back has solved his rough running condition. How long with it last? I do not know but I hope its a permanent fix. Thanks for all the help and understanding these Mopar kits. Luckily the owner had the instructions. Link to comment Share on other sites More sharing options...
