Yellowoctupus Posted February 8, 2025 Author Posted February 8, 2025 Quote Love the extra character the painted on decals add. Protect them with your life The old timer I bought the truck from originally requested I remove them (as it's still an active business). He was probably concerned it could attract negative attention if I robbed a bank with it, or was caught hoon-ing around town or something. I told him it was going to Guam, so he was ok with the decals staying on. Some guy in MA contacted me trying to just buy the doors off it after I bought the truck. If they weren't rust free, I might have considered it, but they're super clean still.
Yellowoctupus Posted April 15, 2025 Author Posted April 15, 2025 Brakes I had 2 major brake issues that came up at the same time, so I went to the junkyard, loaded up on parts and tore into it earlier this week. Good excuse to upgrade. My booster was leaking (drawing air through the pedal side), and the combination switch ( proportioning valve looking gizmo) was also leaking a lot of brake fluid THROUGH the plastic threads for the switch. I initially was going to simply replace the o-rings in the combo valve, but couldn't get any in the correct material on island without waiting for (possibly) another month. The hydraulics store I went to checked the o-ring sizes off a chart (they didn't actually measure them) but said they were the following sizes: Additionally, they MUST BE EPDM. Not Buna, Viton, etc. Take those sizes listed above with a BIG grain of salt as the girl behind the counter had NO idea what EPDM was, which surprised me seeing all of the seals / o-rings etc that they DID have. Anyways, since they didn't have the right seals, I instead bought a dual diaphragm booster from a 2000 WJ Grand Cherokee (this one was a 4.0 with ABS, don't know if it makes a difference). I also used the master cylinder from the WJ, however got a proportioning valve from a late model XJ (2000??). I removed my stock, load sensitive proportioning valve, and removed the 'return line' that goes into the nose of the stock combination valve. There are two modifications you have to do to make the stock brake lever/brake light switch work with the WJ booster, which is to drill the booster pushrod out to 5/8", and a flat needs to be filed on the end of the pushrod to make the light switch work. The distance from the EDGE of the 5/8" hole to the flat is 0.115" I know some folks grind this, but I would caution against grinding as some of those same people took too much off, or said their lights still didn't work (again, either uneven, too much removed, too little removed etc). It took me AT MOST 5mins to file it flat by hand. The XJ proportioning valve bracket will fit on the WJ master cylinder if the holes are cut into slots: The booster hole pattern on the XJ is SLIGHTLY different from the WJ (MJ=3-3/8" WJ is probably ) however the fact that the WJ booster has smaller studs (WJ-M8 vs MJ-3/8") means the studs on the new booster still slide through through the stock firewall holes. The pinch seam above the booster AND to the sides need to be massaged to clear the WJ booster. I over massaged the passenger's side initially. Oops. At first, the master cylinder, which is pretty tall looks like it will hit the hood, but it does not. I believe the WJ push rod is ~1/8"-3/16" longer that the MJ pushrod, which combined with the brake lever mechanical advantage, makes the pedal sit a bit higher than stock (~3/4" higher than the clutch pedal?). Not too bad, but not level with the clutch pedal like I'd have expected. Some washers or a spacer between the booster and the firewall would fix it. I may fix it later; I'll see if it bugs me much driving. In summary, the brakes work GREAT. Way better than the stock, correctly bled setup. The fronts lock up before the rear, and it feels well sorted out. (And I don't have do to that crazy MJ bleeding procedure ever again!!!)
Yellowoctupus Posted April 15, 2025 Author Posted April 15, 2025 Been troubleshooting a few rough running issues, found 3 vacuum leaks!! 1. The intake boot from the MAF sensor to the TB was maybe oil soaked from it's previous life and the rubber got kinda gooey and split. (GM PN: 25180042). The original boot is bonded to the plastic intake tube, however after it's pried/cut off, the new boot is sandwiched on and it's all held tight with the hose clamp. Different than the original design, but seems to be working fine. 2. MAP sensor seal was ripped AND the little 'barbs' were all compressed on one side. It was VERY loose in the intake. (GM PN 16194007 for the LS1 intake) 3. I completely missed blocking off this unused port until I replaced the MAP sensor seal. Oddly enough I found a rubber cap IN MY DRIVEWAY that I have no idea what it came off of but it fit perfectly on.
gvthnks Posted April 16, 2025 Posted April 16, 2025 1st, Nice truck. I love that you're keeping the logos on the sides. Preserves it's character. 2d, enjoy Guam. I lived there for 18 months in '89 and '90. Did some traveling from there, but not nearly enough. If you're into War 2 history, you'll never be this close to some of those sites as you are now. I forgot about the Island Wide 35mph speed limit. I had a Honda Interceptor for a while when I was there. Nimitz Hill was a fun ride up and down. 3rd, None of our work (USMC) vehicles had AC in them. We survived. Of course, I was 18 YO and about 140 lbs so it mattered less. Heck, even our barracks AC didn't work a lot of the time. I had the bike and a Nissan 200sx that I bought for 400$. We referred to it as a Guam Bomb. Had to do a headjob on it to get it running. There was a good machine shop in Agana, although I had to get the head gasket set from the states. I'm sure the internet has helped with most things there, like everywhere else. I'd love to go back and visit some day. Looking forward to reading about your progress on the truck.
Yellowoctupus Posted April 17, 2025 Author Posted April 17, 2025 1. Thanks for the compliment. 2. Guam's been an interesting experience so far. We lived in Hawaii for a few years, and I expected it to be the same, in my head. In some ways it's similar, but in many other ways, it's not. So far people are real friendly though, so that's cool. 3. I've only owned one car that had AC before, so It's not the end of the world not having it (and I lived in Redding, CA where it would be over 115 during the day!) but since it's 95% done, it will be nice to have it completed. I also picked up a Guam Bomb out of my neighbor's backyard, a '95 Mini Pajero 4x4, turbo 660cc. Great for an island with a low speed limit as I don't care how much boost 660cc has, it's never going to be fast!
Yellowoctupus Posted April 17, 2025 Author Posted April 17, 2025 A few weeks ago I got a fuel leak behind the intake manifold, turns out it was the Jeep quick disconnect o-rings. Of course, nothing available at Napa, or any other local parts stores (are you noticing a trend here??) but I had a few quick disconnects I had salvaged over the years that just HAPPENED to have the right size seals in them. Talk about lucky.
Yellowoctupus Posted May 24, 2025 Author Posted May 24, 2025 Finally put my windshield trim back in place! Shout out to @ghetdjc320 who travelled thousands of miles to bring me this trim! The stock trim snaps in place on plastic clips, but somewhere along the way, when I was straightening out the bends/dents in my original trim, I flattened out the little hook/ bend which mates to the plastic clips in the sheetmetal trim. A little heat on a promotional screwdriver and now I have an odd trim tweaker. Just one more in the big box of weird custom tools.
Yellowoctupus Posted May 24, 2025 Author Posted May 24, 2025 Got my subwoofers in and rear speakers installed. Makes that stock AMC radio sound better than it is! I had some 4" Panasonics which someone had put under the dash (poorly), so I put those in the b-pillar trim. In the doors, I put in some speakers (Boston Acoustics??) from some home speakers, and the subs are no-names that I picked up in high school. To put it into perspective, I graduated in 2003, so they're, like a fine wine, "well aged". Seeing how long it took to make a simple sheetmetal bracket, I would suggest if you've got $40 kicking around to just purchase the brackets that are made by one of our fellow MJ'ers, but I had some sheetmetal, and it wasn't a bad project, just a time sucker. Bent wire template showing rear clearance. I took off 3/8" but still didn't have to cut into the Jeep sheetmetal for the magnet clearance. Yes, of course I used a rusty desk drawer I found on the side of the road for these brackets. And no, I did not paint them. If it rusts away inside my truck, I will have bigger issues to worry about. I'll post up the sketch out of my notebook with dimensions, should someone else also want to waste a bunch of time making their own speaker brackets :) Kinda funny that AMC had the wires there, the original stereo has a R/F fader knob, but they never bothered to put in the rear speakers or brackets.
Yellowoctupus Posted May 24, 2025 Author Posted May 24, 2025 Never would have thought of a leak here. (Where the welch plug is pressed into the slip yoke.) I think I have to revisit the RTV again (it's not 100% stopped leaking) with the driveshaft removed so I can goop the sealant in there better, or maybe use JB Weld if I can clean it well enough.
Salvagedcircuit Posted May 25, 2025 Posted May 25, 2025 On 5/24/2025 at 9:58 AM, Yellowoctupus said: Got my subwoofers in and rear speakers installed. Makes that stock AMC radio sound better than it is! I had some 4" Panasonics which someone had put under the dash (poorly), so I put those in the b-pillar trim. In the doors, I put in some speakers (Boston Acoustics??) from some home speakers, and the subs are no-names that I picked up in high school. To put it into perspective, I graduated in 2003, so they're, like a fine wine, "well aged". Seeing how long it took to make a simple sheetmetal bracket, I would suggest if you've got $40 kicking around to just purchase the brackets that are made by one of our fellow MJ'ers, but I had some sheetmetal, and it wasn't a bad project, just a time sucker. Bent wire template showing rear clearance. I took off 3/8" but still didn't have to cut into the Jeep sheetmetal for the magnet clearance. Yes, of course I used a rusty desk drawer I found on the side of the road for these brackets. And no, I did not paint them. If it rusts away inside my truck, I will have bigger issues to worry about. I'll post up the sketch out of my notebook with dimensions, should someone else also want to waste a bunch of time making their own speaker brackets :) Kinda funny that AMC had the wires there, the original stereo has a R/F fader knob, but they never bothered to put in the rear speakers or brackets. Nice
AreWeThereYet Posted July 25, 2025 Posted July 25, 2025 Really cool build, definitely noting this thread in case I eventually end up with an LS.
Yellowoctupus Posted November 11, 2025 Author Posted November 11, 2025 Rear End Saga (probably) Rear end's noisy and leaks at the pinion seal with 3.08 gears (meh). Found a set of gears on a '94-ish Grand Cherokee in the forest, so I pulled them, along with the Spicer Trac Lok carrier. Not sure if I'll bother swapping it in, or try to replace the entire rear end. It'll need new spider gears, bearings etc. In the mean time, I replaced the pinion seal: Spicer 46085 and loosely snugged up the loose pinion nut, but it's still noisy, so I'm sure something's just chewing itself to pieces in there. (Moved this to a new post...here!) Upon closer inspection, the spider gears had some damage, the ring and pinion gears actually looked fine, but the carrier bearings had 0 preload (worn out). If I wanted to use the higher gears, I'd have to get a different carrier, which would mean putting a few hundred into rebuilding the Spicer limited slip I had, OR just get a torsional style locker (seems to be the best bet for the street). Two choices for a Dana 35, Eaton and Powertrax. Typically the Eaton's a little more expensive, but I think the Powertrax had a better warranty , which is why I went with them. No major durability concerns reported from reviews I found online for Eaton or Powertrax, so couldn't use that as a pro/con either. Amazon sent me, instead of my Powertrax unit, as ordered a set of GEARS for a Ford 9-3/4" rear end. To Guam. After calling them, they agreed to refund me my money. Their original response was to pay me something silly like $4 to ship them back. It's a 20# + box, like I couldn't ship them to the house next door for $4. Anyways, I ended up talking to the owner at Quick Performance, who gave me some really good pricing on the limited slip, the carrier install kit (bearings/shims, etc), a solid spacer (for pinion preload), universal joints etc. Probably more money than I would have liked to spend on a Dana 35, but I've got small street tires on it, no c-clips to break, (no spider gears anymore either) so it's unlikely to die anytime soon under my daily driving. It took me a LONG time (like 10+ shim iterations between the carrier /pinion shim sets) but I eventually got a good pattern with good backlash, and good pinion / carrier preloads. Would have been easier to pull the axle I'm thinking, but hindsight's 20/20 they say. Parts: Powertrax Grip Pro GT443527 ZK M35 USA Standard Master Overhaul Kit Model 35 Crush Sleeve Eliminator Model 35 Setup Bearings Spicer U-Joints 5-1310X (non greasable) Here's my END settings: Carrier Bearing, "Gear Side" 0.158" Shim Carrier Bearing, "non-Gear Side" 0.172" Shim Pinion Bearing Shim (located between housing and under outer-race, of inner bearing ) 0.0375" Backlash 0.006" Pinion Bearing crush sleeve eliminator (0.410"+0.030" shims) (located shims towards race, not 'step' in pinion shaft itself). Measured rotation of ~15in*lbs prior to installing seal. (This is close to a few old crush sleeves I measured at 0.440" and 0.480") Final pinion nut torque 190ft-lbs. MY original carrier tag: 8953004770 , 3 08 605324-1 USA Standard Gear Specs: Pinion Bearing Preload: (new bearings) 12-14in*lbs Backlash 0.006"-0.010" Ring Gear Bolts 55ft*lbs Cap Bolts 55ft*lbs Axle seals (inner seals) for "Heavy Duty" axle: Centric 41758000 (non heavy duty 41758001 same OD, but smaller ID). I've only driven it a few miles, but so far so good. No leaks, weird noises etc. It was all rusty so I figured why not flames? Freezing the shaft for a few hours and heating the bearing in my toaster oven at 250F, no pressing required. The axle puller I almost never use came in handy for popping these axles out and the seals. I scavenged the sway bar brackets from a 2004 Rubicon Dana 44 and welded them on my Dana 35 for a future project. I helped my neighbor get his Toyota running and he gave me these King Kong 10 ton Jack stands. Standard 2-ton jack stand next to it for example.
ghetdjc320 Posted November 17, 2025 Posted November 17, 2025 Glad you got it wrapped up! Looking forward to seeing it in the streets now
Yellowoctupus Posted February 12 Author Posted February 12 You just don't think about how heavy industrial toolboxes are until you drag four home at one time ... and you're bottomed out. When I get around to replacing springs, I'm definitely getting some that can handle heavier loads. Heavier springs, airbags, something.
Salvagedcircuit Posted February 15 Posted February 15 On 2/12/2026 at 6:57 AM, Yellowoctupus said: You just don't think about how heavy industrial toolboxes are until you drag four home at one time ... and you're bottomed out. When I get around to replacing springs, I'm definitely getting some that can handle heavier loads. Heavier springs, airbags, something. Oooh. Those look like Lista's! Ain't nothing for a comanche. 2205lbs You sir have good taste!
Yellowoctupus Posted February 26 Author Posted February 26 Yeah, funny thing. When I went to buy the Lista boxes, they said they had two different people that wanted to purchase them before I got there, but neither could figure out how to pick them up and put them in their truck. I was somewhat dumbfounded that someone was going to buy a toolbox but couldn't figure out how to take the drawers out. Lol. It takes time, but probably strips out 80% of their (ridiculous) weight. I am a huge fan of Lista and Stanley Vidmar tool boxes. I still have a Craftsman workbench my parents bought me when I was about 10, and my grandfather's Snap-On top box from the 1950s, but I have honestly only kept them out of nostalgia. I bought all four Listas cheap enough that selling two pretty much paid for the other two which I kept, and I got to customize all of my drawer selections, etc.
Gjeep Posted February 26 Posted February 26 For your driveshaft yoke -- put the sealant on the inside of the yoke. Took forever but I used a small 1" paint brush and mashed it in there. Did it a coupe times. I've done it on 3 yokes and no leaks.
Yellowoctupus Posted February 26 Author Posted February 26 You know, I haven't really given it too much thought in a while, although, I think my new yoke is still leaking somewhere. (I'm Assuming it is at the seal now, not the yoke itself anymore.) I wonder if I could pour some oil resistant Epoxy or a runnier RTV into the bottom of the splines. This is a really long yoke so it would be hard to get in there with a paintbrush. At work one time we had to use a high temperature RTV to insulate heater coils from their electrical connections, and I was able to squeeze it out of a syringe, with interchangeable sized tips. It was laborious but did work well in the end.
Yellowoctupus Posted October 13 Author Posted October 13 Rear Sway Bar Had some parts laying around from the junk TJ Rubicon Dana 44 I brought home, and installed them on my truck. Pretty straightforward, but made a big difference in handling. The truck feels like it stays flatter instead of the rear squatting on the outside corner on fast turns now. Also used TJ end links, with the top brackets from a front TJ quick disconnect end link kit. I made custom brackets on the frame with a 1/4" "nut plate" that slides inside the frame rail. If I were to do this again, I would get brackets like this without having to chop them off another axle housing: they are from Barnes, and are like $15 a set. https://barnes4wd.com/products/tj-rear-sway-bar-brackets Just let me know if anyone wants better pictures. I realize that one's kind of crummy.
Yellowoctupus Posted October 26 Author Posted October 26 Hidden Receiver Obviously not for heavy towing, but way better than the bumper hitch spot for bumper hitch style towing or bike racks etc. Most of the construction details are self-explanatory, however I did weld two Dana 44 ring bolts (7/16-20) to the bumper itself, which bolt onto the Reese hitch part. Necessary, no, but it will help stiffen the entire assembly and helped with the square through hole alignment which could shift pretty easily when you're bolting up the bumper. For now, the license plate is just screwed back in place covering up the hole, but I may mount it on a little 2-in square tube, so it could be removed with the hitch pin, or I may do a hinged license plate bracket. Those are pretty cheap, but I'm not sure if it will get the plate out of the way of the ball or not. If I end up running that aluminum drop hitch, I will probably trim off 2 in from the unused end, so that way I don't accidentally open the tailgate into it.
Yellowoctupus Posted October 28 Author Posted October 28 Bucket Seat Swap These seats came out of a 2009 Hyundai Veloster. They are comfortable, but a pain to get to fit. I had to do a bit of massaging to the tunnel, especially on the driver's side. Also, the Comanche cab is not very long (for legroom) so these seats being taller, and thicker where they touch the back of the cab ends up limiting your leg room somewhat. Better than my old screwed up bench seat, yes. The best seats ever? No. They're good for now. Sound Deadener Butyl rubber backed aluminum flashing repair tape. Roughly $20-$30 per roll at Home Depot. Covered the entire roof (overkill) and did some strips in the aluminum truck cap. Makes a HUGE difference. Holds up to heat too. Cab Rear Panel I actually do not know what this material is, but it is similar to what you find in the trunks of some cars. It has a fairly stiff plastic in the middle, and then it is fuzzy on both sides. Cuts with a razor, not easy but it will cut. Cleaned up the back of the cab real nice. Cost me $5 at a garage sale for two big sheets like this.
Yellowoctupus Posted November 8 Author Posted November 8 Maybe a silly looking fan, but it's an OEM Ford pusher that I reversed the blade on, and reversed the polarity, so it should work fine as an aux unit. My truck (not running AC yet) only occasionally runs the first fan, mainly if I'm sitting at traffic lights. Handy mounting it to the stock 4.0 mechanical shroud though, didn't have to overthink anything else here. If I need a bigger slim fan in the future there's plenty of room to grow in the stock shroud.
Yellowoctupus Posted November 8 Author Posted November 8 LS Coil bracket modification. Number 7 spark plug boot rubbed against the heater hoses, so I sliced the bracket and welded it back together roughly 1 in offset. Still enough room on the stock spark plug wire and now I have clearance at the heater hoses. Not a super exciting update, but maybe a handy hint for other LS guys. The valve cover screw that is closest to the firewall of course does not go in now, but I actually haven't had it in the whole time, as it is almost impossible to get to.
Yellowoctupus Posted November 15 Author Posted November 15 Overcomplicated Air System (WORK IN PROGRESS POST) Goals for this system is to add on to the air system for the following accessories: Air Horns, Compressor style air chuck for airing up tires, and Air Shocks . Air Horns: Mine is used, and came off a dumptruck or something. As expected, they're crazy loud. Bought them for $20 from a neighbor. I'm going to use this solenoid valve off Amazon: ($14 for 2). Like any Amazon purchase, I hope it works ok, as it's pretty cheap... For the Air Shocks, Monroe MA820 is listed by another CC member back in 2010 as being a perfect fit, but that PN doesn't seem to be manufactured any longer. Monroe does have a great catalog online with lengths, eyelet dimensions etc listed. Very handy for cross referencing parts. http://www.monroe.com.mx/catalogo/catalog_old3.pdf https://www.monroeheavyduty.com/downloads/catalog/2018-monroe-mounting-length-chart-hd-commercial.pdf I found the following part #s that I think would fit, I went with the AC Delco option, as I found a new set on eBay for $100 shipped, so that's hard to beat. Stock Compressed Length: ~23" ± 0.5 Stock Extended Length: ~ 14" ± 0.5 Eyelet sizes: 5/8" - both ends. Monroe: MA812 / MA728 (I included the reference photos below, as I think the MA728 is the best choice length wise, but it has a weird end code. I believe it comes with the CP3/CP5, so they could be discarded, and the shock has 5/8" id bushing, like Comanches need. AC Delco: 504-562 GM: 88946652 Gabriel: 49311 (Hijackers) Install Tips from Monroe: (important, always have min 20psi in shocks!) https://www.monroe.com/technical-resources/tech-tips/air-shock-installation-tips.html MISC PNs: Pressure Switch: Amazon shop style air compressor switch. For now. I don't love that it's unsealed, but it'll be ok for now. Overpressure Safety Relief Valve: 200psi Compressor: WABCO 12VDC suspension pump. Came off a damaged pallet of compressors, this one had a scratch or two and was going to be scrapped. (I've had it laying around for like 15yrs!)
