Yellowoctupus
    GUAM
824 profile views
Yellowoctupus's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Overcomplicated Air System (WORK IN PROGRESS POST) Goals for this system is to add on to the air system for the following accessories: Air Horns, Compressor style air chuck for airing up tires, and Air Shocks . Air Horns: Mine is used, and came off a dumptruck or something. As expected, they're crazy loud. Bought them for $20 from a neighbor. I'm going to use this solenoid valve off Amazon: ($14 for 2). Like any Amazon purchase, I hope it works ok, as it's pretty cheap... For the Air Shocks, Monroe MA820 is listed by another CC member back in 2010 as being a perfect fit, but that PN doesn't seem to be manufactured any longer. Monroe does have a great catalog online with lengths, eyelet dimensions etc listed. Very handy for cross referencing parts. http://www.monroe.com.mx/catalogo/catalog_old3.pdf https://www.monroeheavyduty.com/downloads/catalog/2018-monroe-mounting-length-chart-hd-commercial.pdf I found the following part #s that I think would fit, I went with the AC Delco option, as I found a new set on eBay for $100 shipped, so that's hard to beat. Stock Compressed Length: ~23" ± 0.5 Stock Extended Length: ~ 14" ± 0.5 Eyelet sizes: 5/8" - both ends. Monroe: MA812 / MA728 (I included the reference photos below, as I think the MA728 is the best choice length wise, but it has a weird end code. I believe it comes with the CP3/CP5, so they could be discarded, and the shock has 5/8" id bushing, like Comanches need. AC Delco: 504-562 GM: 88946652 Gabriel: 49311 (Hijackers) Install Tips from Monroe: (important, always have min 20psi in shocks!) https://www.monroe.com/technical-resources/tech-tips/air-shock-installation-tips.html MISC PNs: Pressure Switch: Amazon shop style air compressor switch. For now. I don't love that it's unsealed, but it'll be ok for now. Overpressure Safety Relief Valve: 200psi Compressor: WABCO 12VDC suspension pump. Came off a damaged pallet of compressors, this one had a scratch or two and was going to be scrapped. (I've had it laying around for like 15yrs!)
  2. LS Coil bracket modification. Number 7 spark plug boot rubbed against the heater hoses, so I sliced the bracket and welded it back together roughly 1 in offset. Still enough room on the stock spark plug wire and now I have clearance at the heater hoses. Not a super exciting update, but maybe a handy hint for other LS guys. The valve cover screw that is closest to the firewall of course does not go in now, but I actually haven't had it in the whole time, as it is almost impossible to get to.
  3. Maybe a silly looking fan, but it's an OEM Ford pusher that I reversed the blade on, and reversed the polarity, so it should work fine as an aux unit. My truck (not running AC yet) only occasionally runs the first fan, mainly if I'm sitting at traffic lights. Handy mounting it to the stock 4.0 mechanical shroud though, didn't have to overthink anything else here. If I need a bigger slim fan in the future there's plenty of room to grow in the stock shroud.
  4. Bucket Seat Swap These seats came out of a 2009 Hyundai Veloster. They are comfortable, but a pain to get to fit. I had to do a bit of massaging to the tunnel, especially on the driver's side. Also, the Comanche cab is not very long (for legroom) so these seats being taller, and thicker where they touch the back of the cab ends up limiting your leg room somewhat. Better than my old screwed up bench seat, yes. The best seats ever? No. They're good for now. Sound Deadener Butyl rubber backed aluminum flashing repair tape. Roughly $20-$30 per roll at Home Depot. Covered the entire roof (overkill) and did some strips in the aluminum truck cap. Makes a HUGE difference. Holds up to heat too. Cab Rear Panel I actually do not know what this material is, but it is similar to what you find in the trunks of some cars. It has a fairly stiff plastic in the middle, and then it is fuzzy on both sides. Cuts with a razor, not easy but it will cut. Cleaned up the back of the cab real nice. Cost me $5 at a garage sale for two big sheets like this.
  5. Hidden Receiver Obviously not for heavy towing, but way better than the bumper hitch spot for bumper hitch style towing or bike racks etc. Most of the construction details are self-explanatory, however I did weld two Dana 44 ring bolts (7/16-20) to the bumper itself, which bolt onto the Reese hitch part. Necessary, no, but it will help stiffen the entire assembly and helped with the square through hole alignment which could shift pretty easily when you're bolting up the bumper. For now, the license plate is just screwed back in place covering up the hole, but I may mount it on a little 2-in square tube, so it could be removed with the hitch pin, or I may do a hinged license plate bracket. Those are pretty cheap, but I'm not sure if it will get the plate out of the way of the ball or not. If I end up running that aluminum drop hitch, I will probably trim off 2 in from the unused end, so that way I don't accidentally open the tailgate into it.
  6. Rear Sway Bar Had some parts laying around from the junk TJ Rubicon Dana 44 I brought home, and installed them on my truck. Pretty straightforward, but made a big difference in handling. The truck feels like it stays flatter instead of the rear squatting on the outside corner on fast turns now. Also used TJ end links, with the top brackets from a front TJ quick disconnect end link kit. I made custom brackets on the frame with a 1/4" "nut plate" that slides inside the frame rail. If I were to do this again, I would get brackets like this without having to chop them off another axle housing: they are from Barnes, and are like $15 a set. https://barnes4wd.com/products/tj-rear-sway-bar-brackets Just let me know if anyone wants better pictures. I realize that one's kind of crummy.
  7. You know, I haven't really given it too much thought in a while, although, I think my new yoke is still leaking somewhere. (I'm Assuming it is at the seal now, not the yoke itself anymore.) I wonder if I could pour some oil resistant Epoxy or a runnier RTV into the bottom of the splines. This is a really long yoke so it would be hard to get in there with a paintbrush. At work one time we had to use a high temperature RTV to insulate heater coils from their electrical connections, and I was able to squeeze it out of a syringe, with interchangeable sized tips. It was laborious but did work well in the end.
  8. Yeah, funny thing. When I went to buy the Lista boxes, they said they had two different people that wanted to purchase them before I got there, but neither could figure out how to pick them up and put them in their truck. I was somewhat dumbfounded that someone was going to buy a toolbox but couldn't figure out how to take the drawers out. Lol. It takes time, but probably strips out 80% of their (ridiculous) weight. I am a huge fan of Lista and Stanley Vidmar tool boxes. I still have a Craftsman workbench my parents bought me when I was about 10, and my grandfather's Snap-On top box from the 1950s, but I have honestly only kept them out of nostalgia. I bought all four Listas cheap enough that selling two pretty much paid for the other two which I kept, and I got to customize all of my drawer selections, etc.
  9. You just don't think about how heavy industrial toolboxes are until you drag four home at one time ... and you're bottomed out. When I get around to replacing springs, I'm definitely getting some that can handle heavier loads. Heavier springs, airbags, something.
  10. Rear End Saga (probably) Rear end's noisy and leaks at the pinion seal with 3.08 gears (meh). Found a set of gears on a '94-ish Grand Cherokee in the forest, so I pulled them, along with the Spicer Trac Lok carrier. Not sure if I'll bother swapping it in, or try to replace the entire rear end. It'll need new spider gears, bearings etc. In the mean time, I replaced the pinion seal: Spicer 46085 and loosely snugged up the loose pinion nut, but it's still noisy, so I'm sure something's just chewing itself to pieces in there. (Moved this to a new post...here!) Upon closer inspection, the spider gears had some damage, the ring and pinion gears actually looked fine, but the carrier bearings had 0 preload (worn out). If I wanted to use the higher gears, I'd have to get a different carrier, which would mean putting a few hundred into rebuilding the Spicer limited slip I had, OR just get a torsional style locker (seems to be the best bet for the street). Two choices for a Dana 35, Eaton and Powertrax. Typically the Eaton's a little more expensive, but I think the Powertrax had a better warranty , which is why I went with them. No major durability concerns reported from reviews I found online for Eaton or Powertrax, so couldn't use that as a pro/con either. Amazon sent me, instead of my Powertrax unit, as ordered a set of GEARS for a Ford 9-3/4" rear end. To Guam. After calling them, they agreed to refund me my money. Their original response was to pay me something silly like $4 to ship them back. It's a 20# + box, like I couldn't ship them to the house next door for $4. Anyways, I ended up talking to the owner at Quick Performance, who gave me some really good pricing on the limited slip, the carrier install kit (bearings/shims, etc), a solid spacer (for pinion preload), universal joints etc. Probably more money than I would have liked to spend on a Dana 35, but I've got small street tires on it, no c-clips to break, (no spider gears anymore either) so it's unlikely to die anytime soon under my daily driving. It took me a LONG time (like 10+ shim iterations between the carrier /pinion shim sets) but I eventually got a good pattern with good backlash, and good pinion / carrier preloads. Would have been easier to pull the axle I'm thinking, but hindsight's 20/20 they say. Parts: Powertrax Grip Pro GT443527 ZK M35 USA Standard Master Overhaul Kit Model 35 Crush Sleeve Eliminator Model 35 Setup Bearings Spicer U-Joints 5-1310X (non greasable) Here's my END settings: Carrier Bearing, "Gear Side" 0.158" Shim Carrier Bearing, "non-Gear Side" 0.172" Shim Pinion Bearing Shim (located between housing and under outer-race, of inner bearing ) 0.0375" Backlash 0.006" Pinion Bearing crush sleeve eliminator (0.410"+0.030" shims) (located shims towards race, not 'step' in pinion shaft itself). Measured rotation of ~15in*lbs prior to installing seal. (This is close to a few old crush sleeves I measured at 0.440" and 0.480") Final pinion nut torque 190ft-lbs. MY original carrier tag: 8953004770 , 3 08 605324-1 USA Standard Gear Specs: Pinion Bearing Preload: (new bearings) 12-14in*lbs Backlash 0.006"-0.010" Ring Gear Bolts 55ft*lbs Cap Bolts 55ft*lbs Axle seals (inner seals) for "Heavy Duty" axle: Centric 41758000 (non heavy duty 41758001 same OD, but smaller ID). I've only driven it a few miles, but so far so good. No leaks, weird noises etc. It was all rusty so I figured why not flames? Freezing the shaft for a few hours and heating the bearing in my toaster oven at 250F, no pressing required. The axle puller I almost never use came in handy for popping these axles out and the seals. I scavenged the sway bar brackets from a 2004 Rubicon Dana 44 and welded them on my Dana 35 for a future project. I helped my neighbor get his Toyota running and he gave me these King Kong 10 ton Jack stands. Standard 2-ton jack stand next to it for example.
  11. Yeah, I saw that setup bearings were super expensive. Was either planning on trying to do what you said, and reuse the old ones, or just buy another new bearing of the same brand/ part number for that purpose.
  12. Thanks, I wasn't sure how that assembly sealed in the housing, whether they'd get messed up when I pulled them out or not. Sounds good. I'm still not sure whether I should purchase a 2nd inner pinion bearing for setup purposes, and put the pinion shims under the bearing, or press the bearing right against the head of the pinion gear, and shim the outer race to housing for depth. I got my "Powertrax" in today. Yeah, instead they sent me a ring and pinion for a Ford 9.75". Completely useless. Now I have to figure out that mess through Amazon, hope the package doesn't get even MORE damaged going back to Amazon for my refund, and then try to complete the purchase a 2nd time. Not too thrilled about that goof up. They're by FAR the cheapest place for oil changes too. Way better prices than Napa (I recently found). I originally purchased a filter and oil for my wife's car at Napa, it came up to over $60! I think HD was under $40. Not that $20 makes me feel rich, but it's a large % difference.
  13. If you think it springs or some other dry spot, next time you go out wheeling bring a can of WD-40 with you, and then just liberally spray down one area at a time. Like spray down one leaf pack, try to get it to creak again and if it keeps creaking, go to the other leaf pack, and then just keep moving around on sway bars, bushings etc. Etc. It's a little tedious, but I have found metal on metal rubbing that way in the past.
  14. Anyone? I'd like to get some parts on order as soon as possible, I would greatly appreciate any advice. Thanks!
  15. So, I haven't completely torn down my rear end (I did pull the trigger on the Powertrax carrier however)... but I'm trying to get my bearings/seals/shims on order for the install and am a little confused. 1. The R&P I am using is from a ~94 ZJ, and it has the crush sleeve. I thought I read that the non-c clip axle assemblies had a solid spacer/shim assembly, rather than the crush sleeve. Is this correct? I'm not seeing that variation listed in the Dana Spicer parts manual, although they do list the c-clip/non c-clip variations. 2. Do Dana 35 pinion shims go between the head of the pinion and the inner bearing, or between the inner bearing race and the case? I'm pretty sure I have at least 1 shim between the pinion and inner bearing, but the Dana Spicer parts manual shows them going between the case and inner race. 3. For the carrier bearings, on the ZJ rear end I pulled out only those large cast iron 'shims' , if I purchased a carrier shim kit, where would they go? It seems like there'd be no room for them, unless the new carrier was produced intentionally 0.020" (+/-) narrow to allow for shimming to get the pattern right. Unless those factory shims are a weird 2 piece precision shim set? I didn't measure them to see if they were the same. 4. I wasn't planning on replacing the axle bearings and seals at this point, unless I find them to be worn when I pull them out. Will I have any issues (sealing, etc) with popping the axle assemblies out, and popping them back in? (I have a slide puller and the adapters, etc.)
