llhat Posted December 10, 2024 Share Posted December 10, 2024 Question Can the fuel tank vent hose connections be accessed without completely dropping the tank? Have one hose that mysteriously became disconnected, no problem until I filled the tank, and then... leako... Link to comment Share on other sites More sharing options...
89 MJ Posted December 10, 2024 Share Posted December 10, 2024 No idea if you’ve got a long bed or a short bed, but here’s a picture of my short bed tank. The one farthest from the camera would be the passenger side rear of the tank and the one closest to the camera is the driver side front. I don’t think you’ll be able to get to the front one without pulling the tank, but it might be worth a shot. Link to comment Share on other sites More sharing options...
llhat Posted December 11, 2024 Author Share Posted December 11, 2024 long bed, the rear one.... now unsure IF from that vent or fuel sender.... recent fuel pump replacement hired out... believe it is going back to them. was not full of fuel on return, drove it around a bit to see how it worked and get a known position on fuel gauge before filling only rounded off to next tenth gallon or so, did not pack the tank. discovered leak. Link to comment Share on other sites More sharing options...
89 MJ Posted December 11, 2024 Share Posted December 11, 2024 The fuel sender is on the side of the tank, so you might be able to see where it is leaking from. Getting that seal in the right place can be tricky sometimes, so I would lean towards it being the sender. But it would also leak before the tank is full too. Link to comment Share on other sites More sharing options...
llhat Posted December 11, 2024 Author Share Posted December 11, 2024 agree, and it did not leak before filling, such are my suspicions of the vent on top that is more difficult to access... ( murphy's law) Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted December 11, 2024 Share Posted December 11, 2024 Was it leaking while sitting on flat ground or just after a turn? The roll-over valve won't leak if it is just sitting (on level ground) they are the highest part on the tank. The most likely suspect is the o-ring on the sending unit. Link to comment Share on other sites More sharing options...
llhat Posted December 12, 2024 Author Share Posted December 12, 2024 flat ground drips on concrete accumulated drip on bottom of tank but bottom of tank is solid, not rusted out... and it did not leak before first fill-up / nor while driving after pump replacement. Link to comment Share on other sites More sharing options...
gogmorgo Posted December 13, 2024 Share Posted December 13, 2024 Mine leaked from where the filler nose connected to the tank, but the tank also had a rusty spot on the side that was constantly wet with gas. I put a new tank in it. The tank straps hang from the bed, so you either need to drop the tank or cut a hole in the bed to see the top of the tank. The tank isn’t that bad to drop as long as it isn’t full. if you don’t want to drive it until it’s almost out of fuel, disconnect the fuel line and run it into a container, and jumper the fuel pump relay. Wire brush the strap bolts and hit them with penetrating oil the day before you drop it. They’re hanging from J-bolts so you don’t need to back the nuts all the way off, just far enough you can lift the j-bolt out of the hanger. Link to comment Share on other sites More sharing options...
llhat Posted December 14, 2024 Author Share Posted December 14, 2024 thank you for the additional responses. am aware of techniques with removal, as well as using jumper for pump. sending back to folks i hired out to replace pump recently... did not DYI as I just did not want to lie on gravel to man-handle this thing. I DID years ago replace the tank myself after a rust hole was developed from contact with skid plate insulators, a new tank.... and years ago replaced pump myself... but just not this time. should be able to update next week. Link to comment Share on other sites More sharing options...
llhat Posted February 5, 2025 Author Share Posted February 5, 2025 well now later, returned to shop that installed new fuel pump and sender. they reattached the vent line and re-seated the sender o-ring, then filled up the tank with fuel. called me to come examine while there on the lift, (only about 3 miles from me) noted no leaks and has not leaked since. Paid them for the fuel, as they asked and no additional charges.... and they stood by their repair as they should have. 'thumbs up'... Link to comment Share on other sites More sharing options...
