Rick A Posted September 5, 2024 Share Posted September 5, 2024 I have ordered two fan shrouds that are way too small for the fan and radiator for my '86 2.8L V6 MJ (they say "Guaranteed to Fit Your 2.8L V6". The fan is 16" in diameter, the shroud connection points are at the horizontal edges of the radiator sides, about 21 1/2" apart. The fan is offset from center by about 2". I lost the original in the rebuild, and photos on the internet don't give enough detail. I'm wanting to bring the engine bay back to OEM. I've looked at '84-'88 S-10 shrouds for this engine which look like they come in two parts but there are no dimensions in the ordering information. Does anyone have experience with a fan shroud for this engine? Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 5, 2024 Share Posted September 5, 2024 Same fan shroud as the 2.5L. Fun fact, both 2.5 and GM 2.8 share the same radiator and fan shroud. So you might find someone who has one or internet. I know someone recently found an 85 in a yard. It might have the shroud. Link to comment Share on other sites More sharing options...
Rick A Posted September 5, 2024 Author Share Posted September 5, 2024 I have partial pictures of 2.8L V6 engines, and the tops of the shrouds do in fact match what the internet shows for the 2.5L. I'll try one more time, and thank you very much for that information. The parts yards here in San Antonio NEVER have the 2.8L engine but I'll call about the 2.5s. Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 5, 2024 Share Posted September 5, 2024 Definitely 2.5’s are more plentiful and used the same shroud for quite a while. Just make sure you don’t get a YJ or TJ one. Link to comment Share on other sites More sharing options...
schardein Posted September 5, 2024 Share Posted September 5, 2024 There is an 86 XJ with the 2.8 in a yard 1.5 hours from me. I'll be by there again in about 2 weeks, if you would like me to grab the shroud. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 12, 2024 Share Posted September 12, 2024 Thge 2.8 and 2.5 shrouds were not the same, one of them is offset to one side. I had that issue years ago. Someone needs to look into that better. Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 12, 2024 Share Posted September 12, 2024 46 minutes ago, dasbulliwagen said: Thge 2.8 and 2.5 shrouds were not the same, one of them is offset to one side. I had that issue years ago. Someone needs to look into that better. Really? I could’ve swore I’ve seen them as the same part number too. Guess I’ll be looking at my 86 parts book to double check. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 12, 2024 Share Posted September 12, 2024 Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 12, 2024 Share Posted September 12, 2024 Way back when, I wanted to convert to electric fan with a used WJ fan I had. I couldn't use the 2.5 shroud due to the offset, but I had 2 2.8 shrouds that I cut up and epoxied to the fan to mount it, as they were more centered on the radiator. I used it that way for several years. Link to comment Share on other sites More sharing options...
Greenjeans Posted September 13, 2024 Share Posted September 13, 2024 The S-10 isn’t even close. I picked one up and threw it away. My factory shroud was cut in half by some previous owner…. I am just running the top half of my original, it’s all I have. But in south GA it’s working fine. 🤷🏼 Link to comment Share on other sites More sharing options...
zomeizter Posted September 13, 2024 Share Posted September 13, 2024 I removed the shroud off mine when I went with the Taurus e-fan mod, if I find it, you can have it OP. Link to comment Share on other sites More sharing options...
