EUREKA Posted August 4, 2024 Share Posted August 4, 2024 I have an AW4 transmission from a 1991 4.0 MJ. I'm not seeing any difference between it and the AW4 in my 1988 MJ. I was wondering what years and models have identical AW4's to my 1988 4.0 AW4 MJ? Also what are the deference in AW4's from these, Jeep Cherokee (XJ): 1991 to 2001 models equipped with the 4.0L inline-six engine. Jeep Grand Cherokee (ZJ): 1993 to 1998 models equipped with the 4.0L inline-six engine. Jeep Wrangler (YJ and TJ): 1987 to 1995 models (YJ) with the 4.0L engine. 1997 to 2002 models (TJ) with the 4.0L engine. Link to comment Share on other sites More sharing options...
Pete M Posted August 4, 2024 Share Posted August 4, 2024 spline count matters if 4wd. renix years were 21, later are 23. there's a big AW4 writeup in here: Link to comment Share on other sites More sharing options...
EUREKA Posted August 4, 2024 Author Share Posted August 4, 2024 Thanks Link to comment Share on other sites More sharing options...
EUREKA Posted August 4, 2024 Author Share Posted August 4, 2024 Is that the spline count on the planetary gear in the t-case and transmission output shaft? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 4, 2024 Share Posted August 4, 2024 1 hour ago, EUREKA said: Is that the spline count on the planetary gear in the t-case and transmission output shaft? That’s correct. Transmission output shaft and transfer case input. Link to comment Share on other sites More sharing options...
derf Posted August 5, 2024 Share Posted August 5, 2024 There are changes in the AW4 over the years. Good info here: https://naxja.org/threads/everything-you-ever-wanted-to-know-about-the-aw4.1053970/ Link to comment Share on other sites More sharing options...
