brucecooner Posted Sunday at 05:53 AM Share Posted Sunday at 05:53 AM The plastic trim at the front vertical edge of the driver's side window on my '88 is cracking and breaking. This is the rearward side of the bar that separates the quarter glass from the window (see picture). I've hunted and hunted online for it, but no phrase I use seems to get any hits. Is this a piece that is reproduced? Link to comment Share on other sites More sharing options...
fiatslug87 Posted Sunday at 06:25 AM Share Posted Sunday at 06:25 AM Check this post. Link to comment Share on other sites More sharing options...
brucecooner Posted Sunday at 10:01 AM Author Share Posted Sunday at 10:01 AM 3 hours ago, fiatslug87 said: Check this post. "Glass Run Channels" Dang, I'd have never been able to pull those words out of the air to describe it. Many thanks! This is the link from that thread for the part (Summit Racing): https://www.summitracing.com/parts/PQP-GRB-6110-84 And I might as well get a set of those spiffy replacement taillights while I'm ordering... Link to comment Share on other sites More sharing options...
fiatslug87 Posted Sunday at 02:58 PM Share Posted Sunday at 02:58 PM 4 hours ago, brucecooner said: And I might as well get a set of those spiffy replacement taillights while I'm ordering... If you want OEM looking taillights see this if you haven’t come across them. Link to comment Share on other sites More sharing options...
pizzaman09 Posted Sunday at 05:44 PM Share Posted Sunday at 05:44 PM I've changed mine out, did a nice job quieting down the cab, reduced wind noise and window rattle. Link to comment Share on other sites More sharing options...
Htchevyii Posted Tuesday at 05:22 PM Share Posted Tuesday at 05:22 PM I changed out every piece that I could find on my 89 XJ. The only seals that I could not find were The ones on the front a pillar and the wing window seals. I ended up changing to fixed front glass to eliminate the air leaks. The Precision website was helpful in determining the correct part numbers, even though I ordered most of it from Summit Racing. https://www.prp.com/product/?subcategory=Door-Weatherstrip-Kit&catname=Front-Door Link to comment Share on other sites More sharing options...
Gojira94 Posted Tuesday at 06:16 PM Share Posted Tuesday at 06:16 PM 50 minutes ago, Htchevyii said: I changed out every piece that I could find on my 89 XJ. The only seals that I could not find were The ones on the front a pillar and the wing window seals. I ended up changing to fixed front glass to eliminate the air leaks. The Precision website was helpful in determining the correct part numbers, even though I ordered most of it from Summit Racing. https://www.prp.com/product/?subcategory=Door-Weatherstrip-Kit&catname=Front-Door You used this kit after switching to fixed front glass? Looking to do this myself. I currently have fixed 2-piece, per door, arrangement. Being it was sold as a base 2WD/2.5/4-spd I doubt it ever had wings. Link to comment Share on other sites More sharing options...
eaglescout526 Posted Tuesday at 06:43 PM Share Posted Tuesday at 06:43 PM 1 hour ago, Htchevyii said: The ones on the front a pillar and the wing window seals And probably the rear door fixed window too. Link to comment Share on other sites More sharing options...
Htchevyii Posted Tuesday at 10:27 PM Share Posted Tuesday at 10:27 PM 3 hours ago, eaglescout526 said: And probably the rear door fixed window too. The rear door fixed window came in the master kit. It uses similar channel to the roll up window. Link to comment Share on other sites More sharing options...
Htchevyii Posted Tuesday at 10:29 PM Share Posted Tuesday at 10:29 PM 4 hours ago, Gojira94 said: You used this kit after switching to fixed front glass? Looking to do this myself. I currently have fixed 2-piece, per door, arrangement. Being it was sold as a base 2WD/2.5/4-spd I doubt it ever had wings. I did, the vent window had no effect on the rest of the seals. The fixed window seals don't look replaceable, but seem a lot less likely to leak that the opening vent. I wish that they sold replacements for the opening wing window. Link to comment Share on other sites More sharing options...
eaglescout526 Posted Tuesday at 10:31 PM Share Posted Tuesday at 10:31 PM 2 minutes ago, Htchevyii said: The rear door fixed window came in the master kit. It uses similar channel to the roll up window. That kit had one for the divider bar side of the fixed glass? Link to comment Share on other sites More sharing options...
Htchevyii Posted Wednesday at 08:59 PM Share Posted Wednesday at 08:59 PM 22 hours ago, eaglescout526 said: That kit had one for the divider bar side of the fixed glass? yes, It had every piece for the rear door. I snoozed and waited on ordering the front door kit because Summit Racing had it in stock and I was spending too much money at once. Wouldn't you know that when I went to order it, it was out of stock everywhere. I ended up having to piece it all together and it cost an extra hundred bucks or so. Link to comment Share on other sites More sharing options...
eaglescout526 Posted Wednesday at 09:45 PM Share Posted Wednesday at 09:45 PM 45 minutes ago, Htchevyii said: yes, It had every piece for the rear door. I snoozed and waited on ordering the front door kit because Summit Racing had it in stock and I was spending too much money at once. Wouldn't you know that when I went to order it, it was out of stock everywhere. I ended up having to piece it all together and it cost an extra hundred bucks or so. Wow. And I couldn’t get anything on finding the channel for the fixed glass. Glass shop was not helpful. Chrysler catalog didn’t show it as a serviceable part nothin. Guess I should’ve looked at those kits. Link to comment Share on other sites More sharing options...
