eaglescout526 Posted June 9, 2024 Share Posted June 9, 2024 I know this is XJ but honestly, I can barely trust facebook groups to not give me 30 likes and zero advice. And I dont want to join an XJ forum when I know all of you guys are the best and can give a good answer or an opinion on stuff. So on the D30 AMC located its oil sensor on the left side of the pumpkin if you are looking at the pumpkin from behind. This one surprises me, rather AMC just make one axle and issue a plug kit for each on that doesnt have the system sentry, they made two. One with the sensor hole and one without. Same goes with the D35. My 30 does not have the plug nor hole, I want to add it to the 30, but drilling on the side where it goes will be tough as I would either have to cut the LCA bracket, I see that as a BIG no no. Or I drill a hole through both LCA brackets and get to the spot where the sensor goes but I would need to get the right size drill bit in an extreme length. Course another option I have is to drill a hole in the front of the D30 cover and put it there, but from the looks of everything, it looks rather small and compact to where that also could be a challenge. What would you guys do? Pic of the sensor: Link to comment Share on other sites More sharing options...
jdog Posted June 10, 2024 Share Posted June 10, 2024 I'd go an aftermarket cover and drill the cover. They are easier to replace and find Link to comment Share on other sites More sharing options...
jdog Posted June 10, 2024 Share Posted June 10, 2024 Also what exactly does it do, is it looking for level or temp? Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 10, 2024 Author Share Posted June 10, 2024 2 hours ago, jdog said: I'd go an aftermarket cover and drill the cover. They are easier to replace and find That’s an idea! Maybe an armored thicker one would allow for the original cover to get trashed with the sensor in place. 2 hours ago, jdog said: Also what exactly does it do, is it looking for level or temp? It looks for level based on the continuity used by the fluid. The oil completes the circuit and let’s the module know it’s full. Once there’s no fluid to complete the circuit, it shows it as empty. Link to comment Share on other sites More sharing options...
Pete M Posted June 10, 2024 Share Posted June 10, 2024 9 hours ago, jdog said: I'd go an aftermarket cover and drill the cover. They are easier to replace and find this Link to comment Share on other sites More sharing options...
Ωhm Posted June 10, 2024 Share Posted June 10, 2024 10 hours ago, eaglescout526 said: It looks for level based on the continuity used by the fluid. The oil completes the circuit and let’s the module know it’s full. Once there’s no fluid to complete the circuit, it shows it as empty. Need for precise and accurate drilling here for the exact location of the sensor. I think engine oil level was 1qt low, light ON. Don't know what rear axle level SPEC is. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 10, 2024 Author Share Posted June 10, 2024 1 hour ago, Ωhm said: Need for precise and accurate drilling here for the exact location of the sensor. I think engine oil level was 1qt low, light ON. Don't know what rear axle level SPEC is. It’s probably half a quart for both axles given the locations as where they should be. Link to comment Share on other sites More sharing options...
FXWorks Posted June 10, 2024 Share Posted June 10, 2024 I didn't know these sensors were a thing. Are they still available? Part number? Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 10, 2024 Author Share Posted June 10, 2024 1 hour ago, FXWorks said: I didn't know these sensors were a thing. Are they still available? Part number? Theyre for a very old set up I’m putting in my XJ. 84-85 only were the model years it was available. I know they can be adapted to use on an MJ if you found the whole thing. So this isn’t something that will plug n play in an MJ. What I have is the last NOS in the world. There’s some number on it but it’s not the AMC number which I don’t have at the moment. Link to comment Share on other sites More sharing options...
