krustyballer16 Posted April 11, 2024 Share Posted April 11, 2024 Picked up this 1979 jaguar XJ6L the other day. Pretty clean. Floor pans are gone but body is clean. Doesn't start. Anybody know anything about these 4.2Ls? Link to comment Share on other sites More sharing options...
89 MJ Posted April 11, 2024 Share Posted April 11, 2024 I know that most of those by now seem to have SBCs or LSs. I’ve always thought they were a neat looking car. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted April 11, 2024 Share Posted April 11, 2024 Here are some pics of an '84 I used to have Link to comment Share on other sites More sharing options...
pizzaman09 Posted April 13, 2024 Share Posted April 13, 2024 I'm a big fan of vintage Jags, was cross shopping early 00s Jag XJs with the 8th Gen Honda Civic Si when I shopping for a replacement for my Oldsmobile. I can't say I know much about those, appears to be fuel injected, if it was a bit older with a set of SU carbs I could definitely help. In the end it's still an engine, spark then fuel then air. If it has those three it should run. Given the vintage I would expect it to have an electronic pickup distributor. Those cars were known for having a bunch of relays up near or above the radiator, not particularly well shielded from the elements. Good luck! It's a cool car. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted April 14, 2024 Share Posted April 14, 2024 Now that's an XJ! Referring to a topic I started earlier. Don't those have the curse of the Prince of Darkness? The local JY has a '78 XJ V12 that burned to the ground, likely due to the shoddy wiring I saw under the hood. Link to comment Share on other sites More sharing options...
