Whitaker717 Posted February 15, 2024 Share Posted February 15, 2024 I have replaced both my running light sockets with the doorman sockets. Upon inspection, the black rubber pieces at the end of the wires close to the socket are all cracked off. Does anyone have any part suggestions besides Doorman? It’s the socket that houses the amber turn signal and running light. Thanks in advance. Link to comment Share on other sites More sharing options...
cruiser54 Posted February 16, 2024 Share Posted February 16, 2024 Likely every replacement part is chinesium. Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 16, 2024 Author Share Posted February 16, 2024 7 hours ago, cruiser54 said: Likely every replacement part is chinesium. Isn’t that the truth. I just grabbed a couple doorman again. Link to comment Share on other sites More sharing options...
AZJeff Posted February 16, 2024 Share Posted February 16, 2024 You might try going to someone like Del-City and see what sort of sockets they offer. It might be from a different Chinese factory, at least🥴 Link to comment Share on other sites More sharing options...
cruiser54 Posted February 17, 2024 Share Posted February 17, 2024 You got my text? Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 22, 2024 Author Share Posted February 22, 2024 On 2/16/2024 at 7:25 PM, cruiser54 said: You got my text? What text? Lol Link to comment Share on other sites More sharing options...
cruiser54 Posted February 22, 2024 Share Posted February 22, 2024 AzJeff Link to comment Share on other sites More sharing options...
JZLAJeep Posted February 22, 2024 Share Posted February 22, 2024 After having trouble with turn signals and messing with sockets (a lot) and wiring (a lot), we picked up a new front clip wiring harness from the local junk yard and it solved the nagging problems (at least the ones associated with turn signals... ) Link to comment Share on other sites More sharing options...
cruiser54 Posted February 22, 2024 Share Posted February 22, 2024 Always look here: CONNECTOR AND RELAY/RECEPTACLE REFRESHING OCTOBER 30, 2015 SALAD 42 COMMENTS EDIT I suggest unplugging EVERY electrical connection in the engine bay you can find, whether engine related or not, and spraying it out with a good electronics cleaner, visually inspecting the terminals making sure they haven’t retracted into the plastic holder, and then plugging it back together. There’s a critical 10-pin connector for the front lighting system located in front of the air cleaner and behind the left headlight assembly. Don’t miss that one. Also be sure that the connectors to the ballast resistor mounted near the air cleaner housing are clean and tight. ALL of the relays should be removed, the terminals wire-brushed until shiny, and the receptacles sprayed out with contact cleaner. Then plug them back in. I do this on every Renix Jeep I purchase or work on for someone else. Link to comment Share on other sites More sharing options...
