MississippiComanche Posted December 17, 2023 Posted December 17, 2023 Would this Dorman vapor canister work as a replacement for the OEM AMC canister on 87 2.5L? I don't feel like cracking open the original and making a mess. https://www.amazon.com/Dorman-911-261-Evaporative-Emissions-Charcoal/dp/B07KFZ1WPW/ref=asc_df_B07KFZ1WPW/?tag=hyprod-20&linkCode=df0&hvadid=330440990362&hvpos=&hvnetw=g&hvrand=13931123272004678189&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9013748&hvtargid=pla-635725856126&psc=1&mcid=974588679fd639fcbe232a2557a322b7&tag=&ref=&adgrpid=66704631099&hvpone=&hvptwo=&hvadid=330440990362&hvpos=&hvnetw=g&hvrand=13931123272004678189&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9013748&hvtargid=pla-635725856126&gclid=CjwKCAiA1fqrBhA1EiwAMU5m_2O5dfxiiFbgnb3henB865f3VVkgyeCzE_W6Xnkfy9Jgdl66muJdsxoC25UQAvD_BwE
schardein Posted December 18, 2023 Posted December 18, 2023 I don't know about the Jeep 2.5, but according to Dormans website, it fits 74-79 and 82-95 GM. On a Rockauto search, it breaks it down by year and model, most notably Chevy Impala 1976-1995. If you are anywhere near a junkyard, you could pick one up cheap to try. For example, U Pull It in Memphis lists a charcoal canister for $8.99. They have a 1991 Cadillac Fleetwood in stock that uses that part according to Rockauto.
ghetdjc320 Posted December 19, 2023 Posted December 19, 2023 On 12/18/2023 at 7:51 AM, MississippiComanche said: Would this Dorman vapor canister work as a replacement for the OEM AMC canister on 87 2.5L? I don't feel like cracking open the original and making a mess. https://www.amazon.com/Dorman-911-261-Evaporative-Emissions-Charcoal/dp/B07KFZ1WPW/ref=asc_df_B07KFZ1WPW/?tag=hyprod-20&linkCode=df0&hvadid=330440990362&hvpos=&hvnetw=g&hvrand=13931123272004678189&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9013748&hvtargid=pla-635725856126&psc=1&mcid=974588679fd639fcbe232a2557a322b7&tag=&ref=&adgrpid=66704631099&hvpone=&hvptwo=&hvadid=330440990362&hvpos=&hvnetw=g&hvrand=13931123272004678189&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9013748&hvtargid=pla-635725856126&gclid=CjwKCAiA1fqrBhA1EiwAMU5m_2O5dfxiiFbgnb3henB865f3VVkgyeCzE_W6Xnkfy9Jgdl66muJdsxoC25UQAvD_BwE Does your canister not have the replaceable filter on the bottom? I’ve replaced several in the 4.0 canisters but maybe they’re different.
MississippiComanche Posted December 21, 2023 Author Posted December 21, 2023 so mine has the replaceable filter.....but how would I go about putting new activated charcoal in it? IDK just seemed logical that a generic plastic evap canister with relatively same size would work in this case without having to mess with filters or replacing the charcoal.
Ωhm Posted December 21, 2023 Posted December 21, 2023 Maybe this thread can help. Check out the utube video. @MississippiComanche
ghetdjc320 Posted December 21, 2023 Posted December 21, 2023 Here is my take on it though I may be off . The charcoal “activation” creates tiny pores to increase surface area. VOC’s get trapped inside those tiny pockets. The engine then pulls fresh air through the replaceable filter on the bottom and extracts the VOC’s out of the charcoal and into the intake manifold. So the way I see it, the charcoal is not actually serving as a filter, more like a reservoir for VOC’s. If the activated charcoal was actually performing a filter function, then it would need to be replaced very frequently. But by design, the only replaceable item is the bottom air filter. Now if the charcoal inside becomes dirty and clogs the pores of the charcoal (perhaps from a dirty air filter or muddy water intrusion) then it wouldn’t work correctly anymore. But if maintained properly by replacing the filter and ensuring engine vacuum is always present, I can’t see why it wouldn’t last as long as the vehicle. Again, my theory is based on the idea that the activated charcoal is serving more as a collecting medium vs a filtration system.
Ωhm Posted December 21, 2023 Posted December 21, 2023 That seems to sum it up. Let me add the canister vents the fuel tank vapors and pressure to the atmosphere through the charcoal, through the filter (if good) and out the bottom. Under this condition the bottom is an outlet.
MississippiComanche Posted December 22, 2023 Author Posted December 22, 2023 In that case I'm just going to but a new filter and new hoses since they are cracking.
