Hey guys, I just got my heater core replaced and while the heat gets warm I would think it should cook me out of that little truck. Is there anyway to get warmer air in these things? Everything is new. New radiator, evap coil, water pump, thermostat(I’m guessing 180 but idk). Thanks in advance. 87, 4.0
Putting in a stock 195 thermostat will bring your heater temperature up quite a bit. Around here I’ve even known people to put in a 205 for even more heat, although I think that’s overkill. Even at -40 I’ve rarely ever had my temp slider much past half, maybe 3/4 at the most. I don’t do the old-man trick of blocking the radiator either.
Other basic maintenance stuff like making sure the coolant is topped up will help. It’s also worth making sure the blend door is operating correctly, opening all the way. Also that the heater valve is working.
Is there a certain type of coolant to add and how much?
Might you check to see if all the lines are plumbed to the correct spots under the hood and that your vacuum operated heater valve is working under the hood.
Is there a way to test that valve? It blows pretty warm air but I think it should be hotter.
It is a simple vacuum operated valve, I'm not certain which way is open, but you should be able to unplug the vacuum line and rotate the valve from the lever arm to open it up.
Interesting. I will check it out. Thanks
I checked that out and it holds vacuum. There is a lever underneath it you can push in.
Not really. Any 50/50 blend of the old fashioned toxic green ethylene glycol coolant will do the job. The universal premix is okay if you don’t want to mix it yourself.
I personally will buy name brand concentrated coolant for better anticorrosion and wear properties, and spend money on deionized water, again for corrosion, and mix it roughly 2:1, to give myself extra low-temperature performance. It’s a little overkill even for around here but mixing it rich like that will give me a little extra freeze resistance, but at the cost of reduced heat capacity, which has been noticeable in warmer weather.
Running deionized water is probably overkill as well. Distilled would be fine. Honestly even tap water if it’s reasonably soft. I won’t lie and pretend I’ve never topped up with river water strained through a t-shirt in a pinch, flushed and replaced at earliest opportunity of course. But I started running deionized when I had a steady free supply of it and when I changed my ZJ’s original water pump at 200,000 miles it still looked brand new. Even the inside of the block was shiney bare-metal clean. I was only changing it because the bearing was shot. So I figured I should keep doing what I had been doing.
Thanks for the info! I can just see a max line in my bottle.
If you’re still running the closed system that’s probably fine. Keep an eye on it just to make sure it stays full, in case there’s any air in the system that works it’s way through.
If you’ve had an open conversion make sure the pressurized side is still full. It’s possible to have a small leak you’d overlook and have the level drop in the system without changing the level in the overflow. It could push pressure out the leak and then suck air back in instead, and you’d never know just looking at the overflow.
I still have the closed system and there is only about 1/2” filled in the bottle. I’m about 2 or 3” below max line
I use ONLY Mopar thermostats. a little pricey but they warm the engine very quickly and the temp is stable at running temp.
I live in the mountains of Arizona where temps can vary from 0* to 100* F.
