Well ole joe dirt sounds like he's losing a rod bearing..... sounds like i got a small tick, slap, knock coming from oil pan area. Can only hear it when I'm parked in garage or somewhere where i have an echo. Anyway,  i have a 96 h.o motor, ax-15 setup minus harness. My question is, can i swap everything out an make it run on renix computer so i don't have to swap entire harness? Would also like to freshen it up b4 the swap if swap is possible. Who makes the best rebuild kit?  Is a stroker worth it? I can't afford a stroker long block also have a huge shortage (0) of machine shops around here. Any input would be appreciated.
HO INTO RENIX SWAP
This swap is easier than some will lead you to believe. And generally Pooh-poohed by those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it as swapping in a long block.
  • XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange.
  • 2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange.
  • YJ and 1997-1999 4.0L TJ blocks will interchange in XJ/ZJ
  • XJ/ZJ blocks, and the 2000+ TJ/WJ blocks do not interchange without significant modifications.
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
Now that we know which engines we can use, let’s get down to business.
The HO and Renix have some differences but none that can’t be overcome very easily.
One running change was that the rear of the head was no longer drilled and tapped for the temperature gauge sender beginning in the 96 model year. The sender can be relocated to the threaded hole in the thermostat housing taken from an HO engine. You’ll have to extend the wire to that location. Some brave souls even drill and tap the HO head at the rear for the sender.
You will be using the intake and exhaust manifolds from your Renix, along with all your sensors and wiring. Since the intake ports of the HO are slightly different, you use a new Renix gasket. Exhaust ports are identical.
An alternative on exhaust manifolds:
As far as exhaust, you can use the Renix exhaust manifold and be fine.
If you want to use the HO exhaust manifold, you must go with an HO headpipe and screw your O2 sensor into that headpipe. Standard Renix harness is plenty long to do so.
A bung can be welded into the HO manifold to accept the EGR tube.
You will need to use your Renix distributor as it is different than the HO design. See Tips #12 – Setting Your 4.0 to #1 TDC and #13 – Distributor Indexing to be sure you get the distributor installed correctly.
The flywheel or flexplate from the Renix must be used so your CPS gets the correct signals. The valve cover from the Renix allows you to keep your CCV system intact and requires no modifications.
The HO block will have a plug in the coolant galley on the driver’s side of the block, closest to the front, which needs to be removed so your Coolant Temp Sensor can be installed in it’s place just as it is on the Renix. It requires a 5/16” square drive or a modified 3/8” drive that has been ground down to fit. Do this before installing the engine.
As for the knock sensor, which is located just above the oil pan on the driver’s side of the engine about mid way, all the blocks I’ve seen are threaded for it. If not, I’ve heard they may be drilled but not tapped. Tap the hole if that’s the case.
XJ: “Regular” (not Grand) Cherokees ’84-’01
ZJ: Grand Cherokee ’93-’98 (Gen1)
WJ: Grand Cherokee ’99-’04 (Gen2)
YJ: Wrangler ’87-’95 (Gen1)
TJ: Wrangler ’97-’06 (Gen2)
Is your ax15 transmission from
an XJ? As for mods, I’ve built several strokers now. My key takeaway is “underwhelming performance for the amount of investment”. The last build i did was just a modified 4.0 and that was actually a decent engine but still cost several grand in parts alone
I'm essentially doing the same as you're considering, running an HO engine with a 89-90 Renix manual harness/ computer. Your advantage is you have all your Renix-compatible sensors already, only question is if you've done the open cooling system upgrade. The rad I got has a plugged boss for the Renix style fan switch, which was a pleasant surprise, so I'm using the Renix fan switch. My donor is a 93 YJ, so I'm capping the port for the fan switch in the thermostat housing. If I had a Renix t-stat housing, I'd run it instead for the same reason. Only other caveats I can think of are to swap over the speedo gear and possibly the TC indicator switch, not sure if it's the same but probably is. Little things like reverse light switch pigtail being different is a possibility.
If you're comfortable with refreshing the 96 shortblock yourself, new bearings throughout/ inspect all journals is a good thing, though cam bearings can be tricky without the right tools. Very light DIY hone of the bores and new rings would make it pretty happy. So would new valve seals, springs and lapping the valves. Refreshed head with worn rings = burning oil though, and new rings with leaky valve seals also = burning oil so don't do one without the other.
