LS Drag Comanche!
  • 6 months later...
  • krustyballer16 changed the title to LS Drag Comanche!
  • 2 months later...
  • 1 year later...
Guess i should update this a little...
Its no longer an iron block 6.0...I blew it up August 2024...
Its now an aluminum block 5.3. Turbo cam, springs, lifters, rockers...bunch of stuff from Brian Tooley Racing.
I never posted any details from the original build either I guess.
Mildly built 5.3, stock bottom end, stage 3 jakes 4L80, 80mm VS racing turbo, E85, bosch 210 injectors, bigger intercooler now, 8.8, qa1 shocks all the way around, leaf spring sliders i built original leaf springs, rubber bushings replaced with aluminum, engine is solid mounted with aluminum, no rubber bushings.
Probably forgetting something.
It made 550hp on 6psi (bad boost controller).
It saw 24psi last time I had it on the street...
She screams.
2 hours ago, speeding_infraction said:
So what are you doing for suspension? Still solid/beam axles?
Ya, front is still the same, stock springs and the qa1 shocks, I think for a mustang. Not sure  whatever the closest fit length was.
The rear is the 8.8 with the original leafs, aluminum bushings, spring sliders (might have a pic) and qa1 shocks
Liking this build, I am currently doing a RCSB Silverado with a very similar engine/trans combo. can't imagine how it feels in a Comanche lol.
My Comanche with right around 500HP is plenty enough as it is.
