Does anyone know the wiring for these type of switches? I picked up a NOS switch (part 56000025) for my sport bar lights, but I’m unsure which lead is positive, ground, and switched positive. Anyone know?
Also, any tips to run wires from the sport bar to the cabin and battery?
The ground is just for the little lamp on the switch itself. Otherwise it’s just basically a power transfer switch.
you can always use a multimeter and do a continuity check to see which tab is which. I think the bottom one(if you’re looking at it head on with the lamp on the top switch portion) is ground.
Is there additional existing wiring for other optional switches, same as there is for factory fog lights? I know there's a couple connectors under the dash but I've never really investigated anything more than the fog lights.
Mine has fog, cargo and trans plugs. That’s it.
Got it wired up. Luckily the Cargo Light harness was in there. I know it’s always live, but kind of nice to be able to turn on the overheads without the engine on. Will be nice once I get a custom faceplate that will show the Sport Bar lights.
Also, @MJCARENA, did you lose some locking pliers? :laugh:
