Do I have to remove console top to remove the shift boot?
Under the shift boot is a plastic retainer that holds the boot in place. Put one hand on the front of the shift boot(closest to the ash tray) and dig your fingers in the crack between the console and boot and push inward and lift up to release the retainer from the console. Then you should be able to remove the retainer from the boot and remove the boot separately.
24 minutes ago, 87MJTIM said:
I found that the shift boot for a TJ fit for inner boot.
I tried this. never got mine to fit in any way shape or form. Even ordered genuine too and ended up destroying it. Went the 97-01 route and that just doesnt fit, Chrysler made it an oval for some reason.
