jeepaholic Posted December 20, 2007 Share Posted December 20, 2007 I am thinking of doing rear steer on project #2...Anybody ever done this to their MJ? If so give me the scoop. :cheers: Link to comment Share on other sites More sharing options...
carnuck Posted December 20, 2007 Share Posted December 20, 2007 Who's going to make the custom rear axle for you? Link to comment Share on other sites More sharing options...
Badger Posted December 20, 2007 Share Posted December 20, 2007 Who's going to make the custom rear axle for you? why would you need a custom rear axle?just use a front 60 its that easy.the hard part will be not having enough room in the rear wheel wells for full turning radius. this is unless you clipping the rear or tub the fenders out as well as sectioning the frame. Link to comment Share on other sites More sharing options...
jeepaholic Posted December 20, 2007 Author Share Posted December 20, 2007 I was gonna do a dana 60 front and rear..I was thinking of gettin some high steer knuckles and replacing the rear w/ that..I have already done the knuckle rotation on the front of my first project..It wasnt that hard the ughhh 2nd time i did it..I was also thinking just using a joystick control for the rear but be able to lock it in at center when i wanted too...I am just after some pointers and advice from anyone who has done it. :popcorn: Link to comment Share on other sites More sharing options...
jtdesigns Posted December 21, 2007 Share Posted December 21, 2007 I saw a Scout with rear steer before. The guy had what looked to me just like a control value off a back-hoe, and ram's in the back. It was strictly for trail though. I hate to see what would happen on the road if something let go in the rear. Link to comment Share on other sites More sharing options...
carnuck Posted December 21, 2007 Share Posted December 21, 2007 Front diffs don't have a centered pumpkin Link to comment Share on other sites More sharing options...
Badger Posted December 21, 2007 Share Posted December 21, 2007 if its going to see any type of speed then yes it should be taken care of.since he has spun the C's on the front he should be able to figure out how to either A add C's to a rear 60 axle to make it steerable or B retube the short side and cut down the long side then weld C'c back on a front 60 its not really hard to make an axle.the hardest part is being able to press the C back on or in the case of retubing one side to press the tube straight.if you have some brains it can be done.lucky for me a local shop does it for about 500 bucks. Link to comment Share on other sites More sharing options...
Twisty Posted December 21, 2007 Share Posted December 21, 2007 I know a guy who has a GMC Jimmy on rockwells and 42's. He just used the snow plow hydraulics for the rear steer. Link to comment Share on other sites More sharing options...
