Wheel Center Cap Emblems
ghetdjc320
Did you ever end up developing the Eliminator version?  I am getting my eliminator wheels refinished right now, I have two center caps, both of which need emblems.  I will have to make two more center caps or buy two.
The eliminator version is just a smaller turbine version correct? If I don’t render any new graphics, I can make them smaller to fit the eliminator wheels. Let me know the exact size
This is the Eliminator version.  I took several measurements to the edge of the thin metal backer and the average is 43.6mm
Should be simple enough. These are pretty much the same as the turbine versions just a bit smaller it seems. I can make them 43mm to make sure they fit inside. Is the “Jeep” lettering silver or gold?
I think they are silver, I'd prefer they be silver.
Sounds good to me.
Archived
