Everz Posted March 16, 2023 Share Posted March 16, 2023 So i've had a problem for a while now where the fuel pressure will exceed 30 psi right after ignition (usually 40psi) if i’ve drove around and ran a few errands, stopping the motor and starting it again a couple minutes later. What I've noticed is that my fuel pump will prime every time I turn the key whether or not the fuel rail is under the correct pressure or not. Could that be a problem with my fuel pressure regulator or possibly a sensor I'm unaware of. Appreciate any help Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 16, 2023 Share Posted March 16, 2023 Very possible. Check for leaks as well, orings on injectors can be common. Basic fuel supply, pump_tank, filter, rail with injectors being regulated. Link to comment Share on other sites More sharing options...
Everz Posted March 16, 2023 Author Share Posted March 16, 2023 12 minutes ago, MiNi Beast said: Very possible. Check for leaks as well, orings on injectors can be common. Basic fuel supply, pump_tank, filter, rail with injectors being regulated. recently replaced injectors fresh o rings, basically gonna run through it all till its right again Link to comment Share on other sites More sharing options...
cruiser54 Posted March 16, 2023 Share Posted March 16, 2023 Why not leave the fuel pressure tester hooked up on your rides and monitor the fuel pressure? It's common that the internal fuel hose to the pump deteriorates and causes all sorts of fuel supply issues. Link to comment Share on other sites More sharing options...
Ωhm Posted March 16, 2023 Share Posted March 16, 2023 11 hours ago, Everz said: What I've noticed is that my fuel pump will prime every time I turn the key whether or not the fuel rail is under the correct pressure or not. This is normal. 2-3 second prime, every time at KEY ON. Link to comment Share on other sites More sharing options...
