majastee508 Posted February 12, 2023 Share Posted February 12, 2023 Picked up a 92 Eliminator 4x4 auto that has seen some much better days but pretty much fit the bill to let me build it as I wanted based on its current status. I was hoping to find something a bit cleaner to start with but I’m actually pretty happy with it so far. Goal is to build a capable little wheeler that I can take with some local clubs. Previous owner had started to swap the nose for the 97+ look which I wouldn’t have done but will likely leave for now. I also picked up a Tomken front bumper that I liked a lot. So far I’ve started with replacing the rotted Sheetmetal components consisting of rockers, rear wheel wells and drivers cab corner. Have a bit more sanding to do on the pass side and it will be finished. Drivers side still needs the lower rear panel patched(which I see Key Parts has just released 👍). Picked up a used set of 31” ko2’s but not sure the 3” RC lift will provide enough extra for my liking. Installed the front coils and shocks first and it really just leveled the truck out with the stock rear springs in place. Link to comment Share on other sites More sharing options...
majastee508 Posted February 12, 2023 Author Share Posted February 12, 2023 picked up a grey bench seat locally with good brackets and seat belts. It needed a good scrubbing but the chemical guy’s upholstery cleaner worked really well with minimal effort. Will scrub it down one more time before it goes in. Keeping my eye out for a grey mini console Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted February 12, 2023 Share Posted February 12, 2023 Excellent work! Link to comment Share on other sites More sharing options...
89 MJ Posted February 12, 2023 Share Posted February 12, 2023 Looking good so far! Should be a good truck when you get it done. Link to comment Share on other sites More sharing options...
majastee508 Posted February 12, 2023 Author Share Posted February 12, 2023 Here it is with the 30”x9.50’s I picked it up with Link to comment Share on other sites More sharing options...
Pete M Posted February 13, 2023 Share Posted February 13, 2023 excellent efforts saving that truck. (I flipped your pics for you it's a weird glitch in how different devices save the orientation of the photo. I've found that if I rotate it in my laptop, then rotate back, it changes that code and then appears correct each time. phones are a bit different though.) Link to comment Share on other sites More sharing options...
majastee508 Posted February 13, 2023 Author Share Posted February 13, 2023 16 hours ago, Pete M said: excellent efforts saving that truck. (I flipped your pics for you it's a weird glitch in how different devices save the orientation of the photo. I've found that if I rotate it in my laptop, then rotate back, it changes that code and then appears correct each time. phones are a bit different though.) Thanks Pete, couldn’t figure out how to rotate them so I let it fly Link to comment Share on other sites More sharing options...
majastee508 Posted February 20, 2023 Author Share Posted February 20, 2023 Got a bit more work done but not finished with the bedside patches just yet. Waiting on the new key parts driver side rear lower latch panel to arrive. Was able to pick up a grey bench seat locally and got that installed with the mini console. Will be ordering a new carpet shortly. Also tinted the windows and finished off the suspension lift for now. Link to comment Share on other sites More sharing options...
majastee508 Posted February 23, 2023 Author Share Posted February 23, 2023 Was able to find a parts MJ with a Dana 44 rear hiding underneath. Picked up what was left of the truck this evening and will get this cleaned up before installing. Link to comment Share on other sites More sharing options...
