89 MJ Posted January 28, 2023 Posted January 28, 2023 Maybe I'm getting confused with Eagle stuff, but I seem to recall there being a later model mechanical fan that flows more air than the stock 4.0 Renix one. Maybe it was 97+ with a 4.0? And isn't there a later model Jeep e-fan that flows more than the Renix e fan? Thanks.
Airborne Janitor Posted January 28, 2023 Posted January 28, 2023 The later model model XJ fan was redesigned, you can tell by the fan blades. I want to say they started this in 97 XJs, but maybe earlier? The pigtails are different compared to the Renix fan, but nothing a soldering iron can't fix.
89 MJ Posted January 28, 2023 Author Posted January 28, 2023 10 minutes ago, Airborne Janitor said: The later model model XJ fan was redesigned, you can tell by the fan blades. I want to say they started this in 97 XJs, but maybe earlier? The pigtails are different compared to the Renix fan, but nothing a soldering iron can't fix. Thank you sir!
ghetdjc320 Posted January 29, 2023 Posted January 29, 2023 There is also a higher flow mech fan. I just so happen to have one if you are looking for one. Can’t remember the blade count but I have it sitting out in my shop
cruiser54 Posted January 29, 2023 Posted January 29, 2023 Upgrade mechanical fan clutch is NAPA 272310. They tend to be louder than stock and sometimes fit rather close to the radiator.
89 MJ Posted January 29, 2023 Author Posted January 29, 2023 15 hours ago, ghetdjc320 said: There is also a higher flow mech fan. I just so happen to have one if you are looking for one. Can’t remember the blade count but I have it sitting out in my shop I’m not really looking for one quite yet, but if a deal came along I’d interested if you want to sell it.
89 MJ Posted January 29, 2023 Author Posted January 29, 2023 5 hours ago, cruiser54 said: Upgrade mechanical fan clutch is NAPA 272310. They tend to be louder than stock and sometimes fit rather close to the radiator. I had read about that. My radiator is larger than stock, so I don’t think that it would clear.
ghetdjc320 Posted January 29, 2023 Posted January 29, 2023 14 minutes ago, 89 MJ said: I had read about that. My radiator is larger than stock, so I don’t think that it would clear. I ran the mishimoto radiator with that clutch and it cleared just fine. That was on stock Mopar engine mounts
89 MJ Posted January 29, 2023 Author Posted January 29, 2023 33 minutes ago, ghetdjc320 said: I ran the mishimoto radiator with that clutch and it cleared just fine. That was on stock Mopar engine mounts Perfect. Thank you, I shall add that to my list. I’ll send you a pm about the fan too.
