comanche32 Posted December 19, 2022 Share Posted December 19, 2022 So my 1990 comanche has a passenger side running light that won't work. All turn signals brake lights work. It's not the bulbs or sockets. What would cause the running light to not work on one side Link to comment Share on other sites More sharing options...
Eagle Posted December 20, 2022 Share Posted December 20, 2022 What do you mean by "running lights"? The parking lights, or the side marker lights? Link to comment Share on other sites More sharing options...
jpnjake Posted December 20, 2022 Share Posted December 20, 2022 5 hours ago, comanche32 said: So my 1990 comanche has a passenger side running light that won't work. All turn signals brake lights work. It's not the bulbs or sockets. What would cause the running light to not work on one side I know on the late model xj’s they split the harness and had them fused individually, but I’m not sure thsy did that with the Mj’s , other than that. I’d check the wiring diagrams and find the body ground for the lights and clean it up. Bad grounds do funky things Link to comment Share on other sites More sharing options...
comanche32 Posted December 20, 2022 Author Share Posted December 20, 2022 By running lights I mean the tail lights on the passenger side. It's a double filament bulb. The brake and turn signal function fine. But the tail light doesn't. I've tried 3 different bulbs the only thing that doesn't work is the passenger side tail light Link to comment Share on other sites More sharing options...
cruiser54 Posted December 20, 2022 Share Posted December 20, 2022 Does someone have a trailer harness hacked into the back of your truck? Have you used a test light or meter to check for power and grounds? Link to comment Share on other sites More sharing options...
comanche32 Posted December 20, 2022 Author Share Posted December 20, 2022 Yes there is a trailer harness spliced in. It's just weird that the brake light and turn signal part of the light function. But the running light doesn't. Link to comment Share on other sites More sharing options...
Pete M Posted December 20, 2022 Share Posted December 20, 2022 gotta get into the harness and see where the wire has broken/corroded. Link to comment Share on other sites More sharing options...
comanche32 Posted December 20, 2022 Author Share Posted December 20, 2022 Which wire controls the passenger tail lights do you know Link to comment Share on other sites More sharing options...
