Renoenvy08 Posted December 17, 2022 Share Posted December 17, 2022 Could anyone tell me how much the total length of the eliminator ax-15 with a NP-231? I. Think I found a replacement for my eliminator but want to be shure Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2022 Share Posted December 17, 2022 an AX-15 is an AX-15. the length is constant. if the trans has a thick aluminum plate between the front and rear halves of the case, it's an AX-15,. But if the trans has a thick steel plate between the front and rear halve of the case, it's an AX-5 and that won't work for you at all. they look similar, but the middle plate gives it away (also the bolt pattern for the bellhousing is very different but the bell isn't always there). the 231 found in the old Jeeps comes in unsealed rear (89 through maybe 96?) and sealed rears (anything after that). can't say I'm 100 percent that they are the same overall length or not. also, your AX-15 is rebuildable. Link to comment Share on other sites More sharing options...
Renoenvy08 Posted December 20, 2022 Author Share Posted December 20, 2022 I was quoted $3300 to rebuild my tranny and xfer case ( broke 1 gear on cluster and a separate one) this tranny I'm looking at is from a 90 2 door Cherokee, was just curious because a have a eliminator. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 20, 2022 Share Posted December 20, 2022 Eliminator was a TRIM package only for the most part. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted December 20, 2022 Share Posted December 20, 2022 13 hours ago, Renoenvy08 said: I was quoted $3300 to rebuild my tranny and xfer case ( broke 1 gear on cluster and a separate one) this tranny I'm looking at is from a 90 2 door Cherokee, was just curious because a have a eliminator. That is outrageous. You can buy a new AX15 and reman transfer case for less than that from Novak Conversions. Link to comment Share on other sites More sharing options...
