fun with lights
helping a friend with her truck.  don't have time today to dive deeper but I ran through the various selections
only rear hazards flash
only rear left turn flashes
right turn is fine both front and back
no parking lights up front at all, rear parking lights work.
no turns or hazards at all if headlights/parking lights are turned on.  doesn't even click.
bulbs are all good
all sockets look great
good times. :(
see, this is why I don't do technical work on my bad brain fog days.  when I say "the sockets all look good", what I mean is that the ground strap is completely missing from inside the front drivers side turn signal.  :laugh:  can't look corroded if it's not there!
front turn sockets replaced and the turns all work, hazards work, parking lights work, BUT if you have the parking lights on the Hazz/Turns go solid.  soooo.... progress?  :laugh:  tried adding an additional ground from batt to dash, but no change (it fixed several things in my 88 back in the day)
next up I'm going to pull the batt cables so I can go get new ones.  the old are pretty nasty and I want them gone before I dig any deeper.
both hazards and the turns work as they should... riiiiight up until you turn on the headlights too and then the turns/hazards just stay on with no blinking.  I'm pretty sure it's a ground issue, I just gotta find time/energy to really dig in.  this kitchen remodel I'm doing for a friend is sucking the life outta me.  :laugh:
