Sticky accelerator
mine is the same way, I sprayed everything that moves related to it and replaced the throttle body. I may have to go the ghetto way of putting a helper spring to bring the throttle back to idol. hopefully someone can pipe in with a more perminant solution.
Jonathan
get a new throttle cable, they get rusty and can bind up, its a serious safety hazard...
Mine did that when the throttle cable wore out. The cable itself started wearing through the outer shroud and would stick. Very dangerous, fix it soon. It's a dealer item.
