robfg67 Posted December 7, 2007 Posted December 7, 2007 I just purchased a 1989 Comanche. It has the I-6 engine, 5-speed manual, and 4-wheel drive. The truck smells like gasoline even though there is no gas leaking (none on ground below truck). Have any of guys experienced this before? Any suggestions? I will post pictures this weekend.
KYMJ Posted December 7, 2007 Posted December 7, 2007 Check for a leaky injector. I assumed you only looked under the tank and on the ground.
robfg67 Posted December 7, 2007 Author Posted December 7, 2007 Correct-I did not pop the hood before I left for work today. Would I see the gas on the side of the engine if it were a leaky injector?
whowey Posted December 7, 2007 Posted December 7, 2007 You could see fuel laying down in the heat shield tray below the injectors. That's how I found my leaky O-ring. Also the vapor canister could be plugged...
KYMJ Posted December 7, 2007 Posted December 7, 2007 You might see it on the heat shield. You actually might see a stream coming from the injector. They can be hard to trace, one minute they're leaking the next minute, they're not.
deziped Posted December 8, 2007 Posted December 8, 2007 Check with the engine running. My leak never showed any dripping or puddling unless the fuel rail was under pressure. An 89 I believe will only be under enuf pressure when actually running to make it leak. Take a hold of the injectors and wiggle them around. Might want to have a fire ext handy when checking them
DansGreyMj Posted December 8, 2007 Posted December 8, 2007 whats the easiest way to change an o ring on an injector, i just notice one of mine was leaking today.
CWLONGSHOT Posted December 8, 2007 Posted December 8, 2007 I still have a leak somewhere near the tank itself. Nothing ever on the ground and noting noticed underneath. But every time I fill up I can smell it until the level drops down a bit. I changed the "O" Ring on the tank when I did the fuel pump earlier in the year. Its not a major issue,,,but annoying. Good luck finding yours CW
