Vacuum issue? Defrosts under acceleration
89 LWB MJ 4.0L. Block is from a 91 but has a renix head + components. All the old vacuum assist 4x4/CAD components have been removed. She's got a 97 XJ dana 30 front axle with AW4 + NP231. No AC. No heater control valve. 95 XJ brake booster. Using the smaller "vacuum football" with only one port. All EGR/airbox/vacuum lines are installed.
Years back I did the axle/tranny/tcase swap, along with pulling the dash and replacing the heater core/seal and hoses. All the heater/vent/defrost options work fine, blend door works fine. But when I get down on the accelerator (going up a steep hill for example, or merging on the highway) air will begin to blow out the front defrost vents. If the heater or vent was on, air will stop blowing out those vents and be diverted to defrost. If the heater/vent was off then air will begin to come out the defrost vents regardless. Once you come off at accelerator everything returns to normal. Does not seem to affect motor/vehicle performance. Any ideas?
vacuum strength drops as engine load increases.  :L:  but in theory it shouldn't drop far enough to fail at keeping the door open.  it's the job of the vacuum reservoir to hold some reserve for just that occurrence, but I know guys that eliminated it and claim to have no side effects.  the sphere isn't cracked is it?  hose going to it is in good shape?
The most common cause of this is deterioration of the vacuum line(s) to the football (or softball) where they pass beneath the battery tray.
It is definitely caused by a vacuum leak. "All" you have to do is find it.
So here's my current setup. A little redneck...
No cruise, no AC, no heater control valve. Using the smaller late model XJ "vacuum football" with the single port. Checked all the lines under the hood, no leaks. Thinking about replacing the vacuum football with the HO XJ model...
One port goes to manifold vacuum and the other to the plastic tube going through the firewall to the heater control in the dash. Visit the diagram I posted above. The only difference in your case is you will be mounting the ball in the engine bay instead of up under the bumper.
Solved! Seems my vacuum reservoir had a crack in it. I was able to actually pry the whole thing apart with my hands. Found another small vacuum canister with 2 ports, hooked it up and problem solved. I did end up just plugging the 2nd port on the new reservoir without issues. Thanks for the help all!
I would also check the vacuum check valve near the coolant pressure bottle. I had the same issue on my cross country trip because the engine vacuum drops under higher throttle. I took a few check valves from the JY and eventually found one that sealed enough to hold vacuum and keep the ac blowing
