eaglescout526 Posted June 4 Posted June 4 Ahh the Dana cruise control. As long as all else works, the module can be blamed easier than the Renix ECU. I think I’ve got a pile of these back when I was making full kits for folks
Gojira94 Posted June 8 Author Posted June 8 I updated the thread in the Pub on the cruise tester tool. I'm using a GM brake switch and I wired it wrong. My gut told me the brake switch was going to be at the heart of the issue before I started troubleshooting. Not for the reasons I thought, but I think I solved it and proved out the rest of the parts along the way. The regulator could still be bad. Just need a test drive as soon as I can manage it.
Gojira94 Posted June 11 Author Posted June 11 Regulator adjustments pots on my regulator ohm out as follows, will vary some with other regulators: A - Centering Adjustment MIN = 323 ohms MAX = 4150 ohms 10:00 = 1500 ohms (20.83%) B - Low Speed Adjustment MIN = 108 ohms MAX = 3975 ohms 10:00 = 1096 ohms (20.83%) C - Sensitivity Adjustment MIN = 1.9 ohms MAX = 21,200 ohms (100%) 12:00 = 11,260 ohms (50%) I test drove with the following settings: A - 2236.5 ohms (about 11:45) B - 90 ohms (about 8:45) C - 10,600 ohms (about 11:45) Cruise works but it's going to need some adjustments, going to the recommended 10:00 / 10:00 / MAX for A, B, C. Centering was too high, as it set and just kept slowly pulling speed higher and higher. I read some Dana documentation and found out Low Speed adjustment is NOT the minimum speed at which you can 'Set' cruise. It's the minimum speed at which 'Resume/Accel' will begin to resume after a brake or clutch switch is activated, with the cruise switch still set to 'On.'
eaglescout526 Posted June 11 Posted June 11 2 hours ago, Gojira94 said: read some Dana documentation and found out Low Speed adjustment is NOT the minimum speed at which you can 'Set' cruise. Fun fact, AMC testing procedures for testing the module is to set the pots to a “default” and test and see if cruise control engages at 30mph. That’s the absolute lowest it will engage and set at.
Gojira94 Posted June 12 Author Posted June 12 Dana manual says to set cruise around 45MPH, brake and slow to about 18MPH. Then press and hold resume/accel and manually accelerate slowly until the gas pedal starts to pull away under your foot, accelerating back to previously set speed on its own. The speed at which that happens is the "Low Speed."
Gojira94 Posted June 24 Author Posted June 24 On 6/11/2026 at 6:56 PM, eaglescout526 said: That’s the absolute lowest it will engage and set at. Of course you're right - that this is minimum set speed as well. Had myself some tunnel-vision chasing this through every component for several days. So it's both minimum set speed and the lowest speed resume will work. i.e. if you were cruising at 65 and braked and slowed to 20, you'd have to get above the minimum speed before the resume button would be able to pull you back all the way to 65.
Gojira94 Posted Tuesday at 03:58 PM Author Posted Tuesday at 03:58 PM On 6/11/2026 at 4:05 PM, Gojira94 said: going to the recommended 10:00 / 10:00 / MAX for A, B, C. That didn't work. No cruise engagement at all. Now set to 10:00 / back to 8:45 / MAX. I need to move some stashed furniture from a move at the coast I helped with, out of the garage, before I can pull it out again...
