89 MJ Posted July 21, 2022 Posted July 21, 2022 Does anyone have any experience with this fuel rail heat shield on their Renix? I see it says its for a 97+, but I can't see why it wouldn't work on a Renix. https://www.amazon.com/Design-Engineering-010378-Injector-1997-2004/dp/B015NOKWQY
ratrapp Posted July 21, 2022 Posted July 21, 2022 i used it on my gfs 95 4.0 zj.it helped alittle when it was extremely hot outside.the factory started using these on later 4.0s because exhaust manifold heat could cause the center injectors to vapor lock especially during very hot days.
motownXJdad Posted July 22, 2022 Posted July 22, 2022 3 hours ago, 89 MJ said: Does anyone have any experience with this fuel rail heat shield on their Renix? I see it says its for a 97+, but I can't see why it wouldn't work on a Renix. https://www.amazon.com/Design-Engineering-010378-Injector-1997-2004/dp/B015NOKWQY i don't see why it wouldnt work on a Renix either, DEI is a quality product. well known in the drag racing world.
89 MJ Posted July 22, 2022 Author Posted July 22, 2022 1 hour ago, motownXJdad said: i don't see why it wouldnt work on a Renix either, DEI is a quality product. well known in the drag racing world. Thank you!
scguy Posted July 22, 2022 Posted July 22, 2022 2 hours ago, ratrapp said: i used it on my gfs 95 4.0 zj.it helped alittle when it was extremely hot outside.the factory started using these on later 4.0s because exhaust manifold heat could cause the center injectors to vapor lock especially during very hot days. Right, the main cause was the returnless fuel system on the newer models.
