Dandxj Posted July 18, 2022 Posted July 18, 2022 I need a new gas tank for 90 (RENIX) Short Bed. Does anyone have any recommendations for a source or any suppliers to avoid ? Thanks
Big_Mark Posted July 18, 2022 Posted July 18, 2022 I got mine from O'reiley's no complaints, great quality, powder coated grey and fit perfectly I bough new rollover valves from MTS since I don't want to have to change them later (one tank pull is enough)
Dandxj Posted July 18, 2022 Author Posted July 18, 2022 Thanks guys. I noted that the Spectra JP5B tank on Rockauto says it is for a carburetor engine. What would be the difference??
Pete M Posted July 18, 2022 Posted July 18, 2022 4 hours ago, Dandxj said: Thanks guys. I noted that the Spectra JP5B tank on Rockauto says it is for a carburetor engine. What would be the difference?? none that I'm aware of for the tank itself (carbed engines didn't have an electric fuel pump) BUT the only MJ that got a carbed engine was the 86 which came in longbed version only. you'll need a shortbed tank.
Dandxj Posted July 20, 2022 Author Posted July 20, 2022 I went with the Spectra tank and straps. Now to find the J-bolts. Thanks for the help.
Big Dan Posted July 22, 2022 Posted July 22, 2022 GOODMARK GMK2111749681 will work for j-bolts. Available on rockauto.
