Muncher Posted June 11, 2022 Share Posted June 11, 2022 Starting issues. So my I just out a new harness and engine in my comanche and now it's turning over but not starting. Has compression and gets air just tested a spark plug and it had spark as well. Before I put the engine in I turned they key and watched fuel come out of the hose closest to the intake so I think it's getting it to the rail. Would this possibly be my cps? 4.0 5 speed Link to comment Share on other sites More sharing options...
Ωhm Posted June 11, 2022 Share Posted June 11, 2022 Using a voltmeter or 12vdc testlight (preferred) check for Battery_Voltage_(B+) on the following pins (use battery_negative terminal for ground): D1_5: B+ (Hot at all times) D2_4: B+ (Hot during KEY ON/CRANKING). D1_6: KEY ON (B+ (Hot for 2-3 seconds)) or CRANKING (B+ (Hot during CRANK)). Link to comment Share on other sites More sharing options...
Muncher Posted June 12, 2022 Author Share Posted June 12, 2022 So do I need to have it cranking while I test these? And what do they mean if not Power. Link to comment Share on other sites More sharing options...
Ωhm Posted June 12, 2022 Share Posted June 12, 2022 13 minutes ago, Muncher said: So do I need to have it cranking while I test these? Yes. You should see voltage (B+) on those pins while cranking. 17 minutes ago, Muncher said: And what do they mean if not Power. D1_5: Fusible Link for Fuel Pump Relay. D2_4: Ignition Switch. D1_6: Fuel Pump side of the Fuel Pump Relay. Link to comment Share on other sites More sharing options...
Muncher Posted June 12, 2022 Author Share Posted June 12, 2022 So I do know my trucks fuel pump is active when I crank it. Is that what that would be testing for. Link to comment Share on other sites More sharing options...
Ωhm Posted June 12, 2022 Share Posted June 12, 2022 D1_5 & D1_6 would be fuel pump circuit tests. D2_4 checks for IGN SW (I1) voltage. Do you have the fuel pump ballast resistor? Link to comment Share on other sites More sharing options...
Muncher Posted June 12, 2022 Author Share Posted June 12, 2022 No I do not. Nothing on the driver side fender well Link to comment Share on other sites More sharing options...
Ωhm Posted June 12, 2022 Share Posted June 12, 2022 1 hour ago, Muncher said: No I do not. Nothing on the driver side fender well Okay. Just needed to be sure your fuel pump wasn't getting its voltage just from the Starter Relay during CRANK. Link to comment Share on other sites More sharing options...
Muncher Posted June 13, 2022 Author Share Posted June 13, 2022 Yeah it gets it before crank in the accessory position Link to comment Share on other sites More sharing options...
cruiser54 Posted June 13, 2022 Share Posted June 13, 2022 On 6/11/2022 at 11:05 AM, Muncher said: Starting issues. So my I just out a new harness and engine in my comanche and now it's turning over but not starting. Has compression and gets air just tested a spark plug and it had spark as well. Before I put the engine in I turned they key and watched fuel come out of the hose closest to the intake so I think it's getting it to the rail. Would this possibly be my cps? 4.0 5 speed You "watched" the fuel coming out? You shoulda been "dodging" the fuel spraying everywhere. Link to comment Share on other sites More sharing options...
Muncher Posted June 13, 2022 Author Share Posted June 13, 2022 3 minutes ago, cruiser54 said: You "watched" the fuel coming out? You shoulda been "dodging" the fuel spraying everywhere. It was just coming out of the small rubber hose that connects to the fuel rail at the time. It would just pour out when I hit the button. Is that bad? Link to comment Share on other sites More sharing options...
cruiser54 Posted June 13, 2022 Share Posted June 13, 2022 Yes. Link to comment Share on other sites More sharing options...
KA88MJ Posted June 17, 2022 Share Posted June 17, 2022 It never hurts to check the crankshaft position sensor. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 17, 2022 Share Posted June 17, 2022 6 hours ago, KA88MJ said: It never hurts to check the crankshaft position sensor. He has spark. wouldn't have that if CPS was weak or failed. Link to comment Share on other sites More sharing options...
KA88MJ Posted June 17, 2022 Share Posted June 17, 2022 On 6/11/2022 at 1:05 PM, Muncher said: Starting issues. So my I just out a new harness and engine in my comanche and now it's turning over but not starting. Has compression and gets air just tested a spark plug and it had spark as well. Before I put the engine in I turned they key and watched fuel come out of the hose closest to the intake so I think it's getting it to the rail. Would this possibly be my cps? 4.0 5 speed When you say you put a new engine and harness in, has the engine ever been ran, prior to putting it in? Have you checked the timing? Will it start if you spray starting fluid in the throttle body? Link to comment Share on other sites More sharing options...
Eagle Posted June 19, 2022 Share Posted June 19, 2022 On 6/17/2022 at 8:18 AM, cruiser54 said: He has spark. wouldn't have that if CPS was weak or failed. He has spark -- but he hasn't conformed that the spark is occurring when the #1 cylinder is at or near top-dead-center on the compression stroke. He could have the distributor installed 180 degrees out of time. Link to comment Share on other sites More sharing options...
Muncher Posted June 19, 2022 Author Share Posted June 19, 2022 1 hour ago, Eagle said: He has spark -- but he hasn't conformed that the spark is occurring when the #1 cylinder is at or near top-dead-center on the compression stroke. He could have the distributor installed 180 degrees out of time. The distributor was 180 off and it was running for two days. Started putting my interior in and now no spark again and the fuel pump does not prime. Link to comment Share on other sites More sharing options...
